928 Forum 1978-1995
Sponsored by: 928 Specialists
Fresh LSD!
Old 01-14-2006, 04:26 PM
  #31
Bill Ball
Under the Lift
Bill Ball's Avatar
Brian: Not sure. Need to do a little more review and preparation based on all the input above. Maybe in a few weeks, but I'm in no real hurry. It's just nice to have the LSD available.
Old 01-15-2006, 07:07 PM
  #32
IcemanG17
IcemanG17's Avatar
Bill
It will be cool to see the two tire burnouts!!! Just don't spin it into something :>)
Old 01-16-2006, 12:35 AM
  #33
Imo000
Captain Obvious
Super User
Imo000's Avatar
Brian,
With the LSD the tire burnout will be very short. If it was a 5-speed it would be a little easier to do a good one. Its the price you have to pay if you want limited slip, but the extra traction is well worth it.
Old 12-06-2011, 01:31 PM
  #34
Bill Ball
Under the Lift
Bill Ball's Avatar
LSD being installed today almost 6 years later....
Old 12-06-2011, 01:45 PM
  #35
Th Dude
Th Dude's Avatar
Never too late for some LSD in your life, Bill.
Have fun.
Old 12-06-2011, 02:38 PM
  #36
Bill Ball
Under the Lift
Bill Ball's Avatar
Would most agree that Redline 75/90 NS for about 80% of the fluid mixed with regular Redline 75/90?
Old 12-06-2011, 04:30 PM
  #37
auzivision
auzivision's Avatar
Ha-Ha Bill,
I feel like my projects are a couple years behind yours. Let's see my LSD just came in last week. Not sure if I can I can wait till 2017.
Did you do it yourself or leave it to a pro? How about a few pictures and/or words of advice. Any WYAIT items?
Old 12-06-2011, 04:46 PM
  #38
jheis
jheis's Avatar
Bill,
I recently acquired a '89 5spd with LSD & I was getting a lot of chatter, particularly when making a turn from a stop. I searched the gear oil discussions and found a lot of confusing/contradictory information. So, I emailed Redline to see what they recommended.
The Redline tech recommended straight 75W90NS. He said that they used to recommend a mixture, but that the current 75W90NS contains a slight amount of friction modifier, so the basis for using a mixture isn't there anymore.
I drained my diff and added 5 quarts of Redline 75W90NS. Chatter is gone & it seems to be working just fine.
edit. I just found the reply email:
"Thank you for contacting Red Line Oil, some time ago we used a fluid blend in the Porsche transaxles to closely match the original. The 75W90NS now contains a slight amount of friction modifier, for improved shiftability not for chatter control.
In your 928 transaxle the 75W90NS is recommended, if chatter is present from the clutch type limited slip when making a slow/tight turn a slight amount of Friction Modifier can be added, being aware that excess will adversely affect shiftability. Typically Porsche limited slip differentials don’t chatter, if chatter occurs 1 to 1½ % would be a good starting point. The 75W90 contains 5% friction modifier too slippery for the synchros so not recommended for use in a manual transmission/transaxle."
Straight 75W90NS worked for me - didn't have to add any friction modifier. By the way, 1 to 1½% would be about an ounce.
Oops! Just remembered that you have an automatic ... Nevermind.
James
Old 12-06-2011, 04:48 PM
  #39
T_MaX
T_MaX's Avatar
Congratulations Bill, I know how long you have been awaiting this mod!
Old 12-06-2011, 05:15 PM
  #40
Bill Ball
Under the Lift
Bill Ball's Avatar
So, I could start with straight 75/90NS and if it doesn't chatter, that's it. If it chatters, suck some out and add some 75/90.
Old 12-06-2011, 05:19 PM
  #41
Bill Ball
Under the Lift
Bill Ball's Avatar
Originally Posted by auzivision
Ha-Ha Bill,
I ended up having a pro install it. I could have done it but since I decided to have a pro fix my tranny leak (and give the internals a once over) after I botched it, I just brought the diff to him to do as well. There are some threads on LSD swaps.
Old 12-06-2011, 06:06 PM
  #42
auzivision
auzivision's Avatar
Thanks Bill, I will most likely do the same. That is have a pro do it and fix/replace seals and mounts. What internals did they 'once over'?
I still haven't got around to getting my SC setup dialed in yet so who knows, it might be six years;o
Old 12-06-2011, 06:27 PM
  #43
heinrich
928 Collector
heinrich's Avatar
I love a fresh LSD in the morning ... Bill, now you can eat your cookies with some fava beans and a nice chilled Fresca.
Old 12-06-2011, 06:32 PM
  #44
danglerb
danglerb's Avatar
So, time for a new burnout video?
Old 12-06-2011, 08:22 PM
  #45
IcemanG17
IcemanG17's Avatar
unlikely since he sold the supercharger :>(
Quick Reply: Fresh LSD!
