Fresh LSD!
Under the Lift
This arrived yesterday. It looks like it came from a freshly slaughtered drivetrain, as it is still dripping blood red diff oil - nice clean diff oil - and the diff looks to be in very good shape. THANKS JIM!
![](http://billsworkshop.com/billsworkshop.com/P928S4/xpics/lsd01.jpg)
Upgrade for traction purposes. My car is open diff.
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Originally Posted by mspiegle
aww, can we still expect to see you as a contender at the 2006 Sharktoberfest burnout competition? ![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Cottage Industry Sponsor
...as it is still dripping blood red diff oil
Well, I always knew you wouldn't stop with just a supercharger. And with the LSD your shark will do the fishtailing appropriate for the species.
Captain Obvious
Super User
Super User
Darien,
Have you checked to see if yours has one? My has option 220 and it cuts down on the burn out to approx. 75ft ( 1st and half a 2nd gear). Visually an open differential is a lot more entertaining.
Captain Obvious
Super User
Super User
Originally Posted by Vilhuer
Did Jim also send pinion shaft or did you split matching pair?
That’s a good point. The pinion and ring gear should always be kept together as a pair. I would just transfer the original ring to the new dif. and reinstall it.
Under the Lift
You guys are certainly correct. I was a bit surprised to see the ring gear. Either the tranny (and mated pinion gear) it goes to is trash, or I will send it back to Jim.
This will be my first diff swap. I am aware of shimming, backlash etc. Retaining the original pinion-ring pair and the same diff case seems to obviate all but the shimming for backlash. A few others that have swapped diffs like this say there was no adjustment needed for them.
Captain Obvious
Super User
Super User
Bill,
It would be a waste not to send it back but then again they probably have so many that they really don’t care if this set gets scrapped.
