928 Forum 1978-1995
Sponsored by: 928 Specialists
Drilled Crank Thoughts...
Old 06-25-2009, 12:17 PM
  #496
Kevin Johnson
Kevin Johnson's Avatar
Originally Posted by entropy_engineering
Ok I should probably stay quiet but have to ask anyway. I've read the posts in this thread (or atleast I think, they all started blending together) and a couple other threads. The recurring question keeps popping up to me, why the 2/6 failure if the oiling path in the crank is the same on the other throws?
Erkka put up a nice diagram of the oil passages and depths in the bedplate a while back. The 2/6 path is the closest to the main feed and has a smaller diameter, ergo pressure reduction which allows compressed entrained air to evolve.
Rest assured that if you could change that the failure would occur in another location. The oil galleys are not the problem. They are an advanced design.
What single element has riddled this throw but not the others? To affect this throw only you can't blame oil quality
Dead stop. Yes, you can blame the oil quality with respect to the amount of entrained air.
or pressure or really crank design. I'm not refuting the validity of the dry sump, windage tray, or especially a drilled crank, but they don't answer my question. The only information I have really found is the distribution network in the bedplate/block design. And if it was aeration the dry sump alone should fix it.
Dead stop. No, not necessarily. The Corvette has a factory drysump that can be overwhelmed by too much aeration. Things are not so straight forward.
If it was harmonic resonance the other stroke/make cranks should have other problems. Do the #2 mains show faster wear as well?
Has anyone tried tapping an external oil pressure line to feed the #2 main? or the others for that matter? It's cheaper than any other mod I've seen besides Amsoil. Makes me think of Ford trying to race the old FE big blocks. Cranking up oil pressure never helped enough, but the side oiler block with priority feeds to the mains took care of it.
The 10psi per 1000rpm was/is a heuristic attempting to overcome entrained air. Priority feeds to the mains is a way to keep this pressure up and entrained air bubbles small and uniformly distributed.
Old 06-25-2009, 12:20 PM
  #497
ew928
Owns the Streets
Needs Camber
ew928's Avatar
Anyone frothed up some hot engine oil in a blender and tested to see which oil is best at shedding the bubble/foam? Or was it covered already.
Old 06-25-2009, 12:30 PM
  #498
mark kibort
mark kibort's Avatar
I had the Hoosiers A6s this weekend, so that blows the more grip will cause issues . 2 full races, no issues. no cooler, no accusump, no baffle, no breather problems, near redline shifting on all shifts, 250-260 degree oil temps, and Amsoil!
Old 06-25-2009, 12:37 PM
  #499
Kevin Johnson
Originally Posted by BrendanC
Sometimes problems are complex. Sometimes they are very simple. The story about NASA needing to come up with a writing instrument that works in zero-gravity, spending millions of dollars and not getting it right. The (Insert other country here - probably russians) just used a pencil.
The crank issue may be very simple. It may be very complex.
Two things have fixed it.
I would add the obvious third, the windage control system I designed and that has been tested over several years now. It certainly works up to a reasonable G-level. I have heard of three engine failures; all owners admitting that the failure was not due to the system: 1) one involving a rare factory mismatched cap with matching serial numbers -- if the rod had been resized this should have corrected it; 2) one involving a fatigue fracture of a piston skirt that then bounced around in the engine; 3) a failed timing belt.
I have to mention 3 because it seems that the system is imagined to confer a cloak of invulnerability on all other parts.
1) Dry sump - This branches into two underlying "solutions"
- Oil aeration in the crank area not getting enough time to DE-aerate.
- Oil pickup uncovering.
2) Drilling the crank - which is a bit more straight forward - oil was not getting to the rods *as well* at high RPMS. Over 6800 I think. Call it 7k.
Doing these TWO things can seem like a big deal. The dry sump is "expensive" but any real race car has them, so its kind of a no-brainer. The drilled crank is even more straight forward. When you rebuild a motor - any person wanting to win would - you have the crank in your hands - why not send it in to get it drilled.
The situation changes when you want to drive your car every day like me. You would need to find a very interesting place for the oil tank. Probably in the fenders in front of the doors. Thats alot of weight in a weird place, but it would be "low". Another place is in the back, but that adds weight and complexity.
I remember people mentioning both dry sumps and drilled cranks allowing the 2/6 rod failure.
Old 06-25-2009, 12:38 PM
  #500
Kevin Johnson
I heartily suggest doing this. It should be a published spec for oils. Good luck with that.
Old 06-25-2009, 12:43 PM
  #501
Kevin Johnson
Yawn. The engine was designed to be raced at 7200 rpms. I mean let's get real here.
Race the car the way it was meant to be run. Its a P O R S C H E
Mein Gott.
Old 06-25-2009, 01:15 PM
  #502
ptuomov
ptuomov's Avatar
Originally Posted by Kevin Johnson
If you want an example of a properly cross-drilled crank, then look at the Mazda BF/B6 and BP cranks. People seem to think I pull this out of thin air. These cranks run reliably well in excess of 8000 rpm. Mazda understands stratification. Ricardo did as well.
Do you have a link to materials on this? I'd love to learn about the Mazda BF/B6 and BP crank designs. If you have something that is not on the web, please post it here or email it to me at <my RL username>"@"<name of the email service by google>"."<first three letters of word commercial>.
Old 06-25-2009, 01:23 PM
  #503
Kevin Johnson
http://cgi.ebay.com/ebaymotors/MAZDA...Q5fAccessories
The pic is helpful. The visible opening on the rod journal passes through to the opposite side. If you're serious about it you should snag a junk one. I learn a lot about engines by having them in front of me to study.
Old 06-25-2009, 01:47 PM
  #504
ptuomov
ptuomov's Avatar
I am a big believer in examining a wrecked engine before working on a working one. I bought a fire-damaged '89 S4 engine just to take it apart and see what's inside before opening a working engine. Learned a couple of things already that are better learned on a wrecked engine.
So, to follow up on the topic. There's a couple of ways to combat the problem you are focusing on. Please correct me if I have misunderstood this:
First, whatever air there is in the oil should stay evenly distributed in the oil. Removing anything that causes separation of oil and air in the oil passages helps.
Second, whatever air there is in the oil should be somehow separated in the wet sump/pan. Any mechanism that separates air and oil before the oil pickup in the pan helps.
Third, anything that prevents air mixing in the oil in the first place helps.
Is this basically it? Or have I misunderstood something here?
Continuing on the first topic, is the "Taylor driller" crank as diagrammed in Dennis Kao's photos the best way to do it? Is the Taylor path design the same as the Mazda path design? See the diagrams here: http://gallery.lasttenth.com/main.php?g2_itemId=1440
Old 06-25-2009, 05:14 PM
  #505
mark kibort
Lets get real here. You dont know what you are talking about. (racing, and getting the most out of a 928 engine) Have you seen the HP curve for not only the holbert engine, but the stroker engine I race?
If you shifted at 7200rpm, I would be running all over you! You know why? HP curve shape and breadth. 4500rpm to 6500rpm gives me the highest ave HP possible.( HP-seconds maximized) Any higher or lower and you LOSE!!
But, if you just like to beat up your equipment like many of my competitors that do lose engines after a season or two ,or less, then knock yourself out. (I count on the misread of most of my competitors HP curves to win races with a lesser car!)
I have one comment. 1:37.5 at Laguna seca. 1:37.8 with a stock engine with a set of headers. Still think Im not driving the snot out of it?
Watch the last race video, then comment!
http://www.youtube.com/watch?v=xYbFeIai2Ng
mk
Mein Gott.
Old 06-25-2009, 06:38 PM
  #506
ptuomov
ptuomov's Avatar
Default big cams
MK --
So, if someone would give you big cams for free, would you put them on? And if you would put them on, would you harvest more hp-seconds by racing it at a higher rpm or would you choose to save the engine? Decisions, decisions, although hypothetical...
My point being is that getting the most hp-seconds out of any (normally aspirated) engine means making choices during the engine building stage that lead to an engine that will produce those hp-seconds at high revs. To reconcile your difference with KJ, one could say that you are talking about racing the engine that you have in the car and KJ is talking about building up an engine to get the most hp-seconds possible.
This is not just hypothetical. You could have your S3 cams reground to more aggressive profile, for example by Elgin/Morton.
Best, Tuomo
mk
Old 06-25-2009, 08:04 PM
  #507
Charley B
Charley B's Avatar
I mean let's get real here.........Mein Gott.
Holy Crap!!!! Two of my favorite people at each other's throat's. Now who do I root for?????
Old 06-25-2009, 09:04 PM
  #508
mark kibort
I get it loud and clear and you are right. Kind of analogous to running my engine with stock transmission because I know if I run it with the power I have now,it wont blow. To your point, yes, if I could have andersons HP curve and a transmission to support it, you bet-cha! Then, and only then would I be thinking about coolers, baffles, accusump, drysumps, etc. I do think the drilled crank is a great idea and Have one as well, BUT, the Holbert car motor didnt have it drilled and its in fine shape after 106 race days!
I only said something back because you said I wasnt driving like it was ment to be driven. according to the HP curves of both. I am.
PS: as a side note, I wonder what the reground cams would do on my engine now. Of course Ill end up doing it someday. Hopefully, on the big motor, and not the old 5 liter like dennis'.
MK --
Best, Tuomo
Old 06-25-2009, 09:17 PM
  #509
Stan.Shaw@Excell.Net
Stan.Shaw@Excell.Net's Avatar
In a 928 with a dry sump, who? Has to be a pretty short list of 928s with dry sumps.
Old 06-26-2009, 12:00 AM
  #510
ptuomov
ptuomov's Avatar
If you get me your engine specs now with a dyno graph, I might come up with a simulation model for it. If I can match your current engine, then I can give you hypothetical power curves using different cam durations and lifts (assuming S3 lobe separation angle and some reasonable cam advance/retard). From those, you can choose what you want and then talk to Jim Morton and Dema Elgin about what is achievable and at what cost.
How about it, you post your engine mods and dyno curves here and I'll try to model them with EAP?
Quick Reply: Drilled Crank Thoughts...
