928 Forum 1978-1995
Sponsored by: 928 Specialists
DOOR Not Opening from outside
Old 12-16-2005, 07:42 PM
the flyin' scotsman
the flyin' scotsman's Avatar
Guys.......I had a similar issue with the drivers door; wouldn't open from the outside. I dismantled the inner door panel completely, got the anti-theft device out and noticed that the adjustment rod was loose. Not having WSMs at the time I adjusted it inplace as tight as it would go checking the outer operation as I went. Problem solved............been fixed for years now.
Be prepared for tight cramped spaces, scraped knuckles etc.
Old 12-17-2005, 02:48 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
Thanks, Malcolm. I hope that's all it is. Mike will be over shortly to have a look.
Old 12-17-2005, 08:39 PM
Brett928S2
Brett928S2's Avatar
Hi,
I just had same problem, sometimes it opened fine ,most times not...thought it might be adjustment....but it was the usual broken backplate,,,changed it,,around 90 minutes.dumped the anti theft plate ...door now opens perfectly and handle is much lighter to pull than its EVER been,
Hope this helps.
Brett
928 S2 AUTO V8 4.7 LTR 1986 IRIS METALLIC BLUE WITH PROMAX CHIPS, RMB, KICKDOWN SWITCH.
Old 12-18-2005, 02:45 AM
Bill Ball
Under the Lift
Bill Ball's Avatar
Bad weather for working outside today, so we cancelled the session. We will get to it over the holidays and report back.
Old 12-18-2005, 08:33 AM
the flyin' scotsman
Bill...........can relate; minus 23C yesterday. All non urgent outside work moved out 'til March/ April.
Old 12-18-2005, 01:02 PM
perrys4
The Lady's Man
perrys4's Avatar
Wink
Wuss!!!
Old 12-18-2005, 07:48 PM
IcemanG17
IcemanG17's Avatar
Bill/Mike
Let me know when your gonna work on it! Georges website helps a bunch too!
Old 12-19-2005, 01:16 AM
Bill Ball
Under the Lift
Bill Ball's Avatar
Brian: Yep, I read over George's stuff several times. We are shooting for next Monday (after Xmas). Mike is off Mondays and I'll be off that whole week.
Old 12-19-2005, 05:01 PM
IcemanG17
IcemanG17's Avatar
Bill
That will work! I'm off as well! Usual time?
Old 12-19-2005, 06:20 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
Yeah, 11 am.
Old 12-19-2005, 08:21 PM
Mark87AT
Mark87AT's Avatar
Oh cool! I am also off next week so I think I can make it over too! my drivers side handle is loose and need to open things up to avoid the inevitable and impending loss of function!
Mark
Old 12-19-2005, 09:53 PM
Randy V
Randy V's Avatar
A tip that may help -
It is easier to work on removing the anti-theft plate and replacing the door handle mechanism with the window fully up, not down as indicated in a couple write-ups I've seen.
On removing the anti-theft plate, just loosen the 10mm bolt that connects it at the bottom, don't completely remove the bolt.. The plate attachment is open-ended, so it will slide out/back in with the bolt loosened.
Old 12-19-2005, 10:12 PM
Bill Ball
Under the Lift
Bill Ball's Avatar
Good reminders, Randy. I believe George has the one about the lower plate bolt in his write-up.
Mark - Come on over. Haven't seen you in quite a while. Heck, anybody that is off that day, come on by.
Nicole - want to do your oil cooler that day?
Let's hope for decent weather. It rained enough this weekend for a month.
Old 12-19-2005, 10:31 PM
gersar928
gersar928's Avatar
I will be off on Monday, so I'll take you up on your offer and drop by. I also have all the supplies for an oil change.
Old 12-20-2005, 12:21 PM
IcemanG17
IcemanG17's Avatar
Bill
Monday @11 will work....I'll hook a ride with Gerry! Gerry's got a bad oil pressure sender (pegged @ 5 bar)...but thats an easy fix (he also doesn't have a belly pan!)
Quick Reply: DOOR Not Opening from outside
