The Twin Screw Thread
#2851
Bump for some info / pics of the S4 throttle bracket mounts. DR or Keel mount brackets!
I've decided to swap the stock throttle bracket on Rocket and install the S4 setup but I need help on the Mount bracket for the S4 throttle quadrant.
No need to have the longer cables and S3 throttle quadrant. I've already got the S4 throttle cable and quadrant, just need the kickdown cable and mount bracket
Looking for info and pics of the S4 throttle quadrant mount bracket and throttle cable routing?
See pics...arrows to the S3 t-quadrant and SC t-cable to the t-body. Arrows to the S4 quadrant and SC t-cable to the t-body. What holds the S4 quadrant in place??
I can use the additional space up front and the S4 setup looks cleaner to me. Not to mention the throttle pedal stiffness.
#2852
Air filter systems for the TwinScrew
What are you all using for your air cleaner housings, and where are you locating them?
I had thought about going through the right side inner fender, but I have my Air/Oil separator in that space, as well as the intercooler pump and plumbing. (below)
I looked at modifying the 928 Motosports radiator cover air-filter and housing, but Carl's being oblique about it.
I'd appreciate any pictures of other installations.
#2853
Can you show a couple of pics of the engine compartment?
#2854
Darien, I was looking through some of my pics and I saw these two that somewhat show the throttle quadrants. This weekend I'll try to get a good pic of mine. Of course it's not on the engine. I left it in the engine bay when I pulled the motor.
Andrew Olson's DR set-up.
My Supermodel set-up.
#2855
Here's one from earlier in this thread, I'm rereading it again in prep for my SC install.
I did reinstall of Ancor MM's last night (they are about 10mm shorter than the Volvo's) to gain some clearance for the headers (to close to the TT cross brace on right side).
I have three things yet to work out:
1. PCV ventilation/oil fill (I have the stock Andy Keel plate with the 1/2 " 90), I see where Bill B. changed it to a 1")
2. Manifold gasket, also considering using studs
3. Fuel Pressure regulation (the BEGI?) or an S4 regulator?
24# or 30# injectors(and tune them down)?
My goal is not to go inter cooled this summer, just get it running.
#2856
Dave given the amount of work involved in removing it all to install the intercooler, I would install it now, even if you don't plumb it all the way and hook it up. Save you some hours down the road.
I would go for S4 regulator and the 30# personally. (+ Shark Tuner) What came out of the car the system was installed on? I have a set if you need/want.
#2857
Hi Chris, well the story is the inter cooler was discoed when I bought the car (internally leaking??) and the car was running good with stock 24# injectors and a with a stock regulator(280-160-215) the BEGI was in a box of parts. The S4 reg P# IIRC is 280-160-297
I need to pressure test the inter-cooler (should not need to hold much pressure, 5lbs to leak test?) and also see what others here have noted the in/out pipes have no lip on them to securely hold a hose.
I have 7 of 8 30# injectors (red top) in a bag, one was missing and no longer have 8 24# as I use one I had to replace a leaking one on the car I restored back to stock.
So I would like to do the 30# ers and Shark Tune as you suggest but am shy one
Now that the Pizza car is back to stock and is hopefully in it's new home, I'm concentrating on the SC install each day after work. The Pan gasket, MM's and Headers were first, I also had to exchange the Washer Tanks between the cars as one was modded for the Inter-cooler pump.
Today's plan is to resolve the Header clearance issue, get the X pipe installed to the Magnaflows and get her off the stands.
Is it possible to bolt headers on wrong?
There are two sets of holes but it looks to me like i used the same set on both sides, however one side was and still a bit tight to the underside.
I'll take some pic's from under in a bit.
Thanks Chris, I can't wait to get this one running even at low boost
Dave
Dave
#2860
With Colin Jensan's help I installed these #61 injectors into my AK autorotor kit manifold using these bushings. Also employed his vacuum pump PCV system. Shark-tuned now @ 8 psi, and ready to roll.
#2861
This is the airbox that attaches to the intake of the supercharger with the inlet at the bottom.
Here is the airbox attached to the front of the SC.
Here's a couple shots looking up at the airbox from below the engine compartment. Taken from just in front of the AC compressor. Sorry for the poor quality. My cell camera is crap.
This shot shows where the flex hose comes out of the fender well under the radiator and connects to the pipe leading up to the airbox.
#2862
Thanks for the pics guys!! I think that I can mount a bracket to the fuel rail (I'm calling it "shroud"). See pic.... It's rigid enough and will make for a good mount location.
#2864
Damn, 61# injectors! Never seen or heard of anyone running that much injector at that low of boost. Is there a drawing for those injector bushings out there? I kind of wished I had gone with the later style injector as there are LOTS more options out there.
#2865
