The Twin Screw Thread
#2836
I have another $3600 headed to him after I get back from Vegas on the 20th.
#2837
Rainman
Anybody "read the plugs" to check even AFR/air flow distribution to the outer cylinders with the pizza-box manifolds?
Am concerned with the outermost (I would say they are 1/4, 5/8 cylinders?) ports being sort of "shrouded" in the valve sense by having the plenum wall right next to the port, whereas the inner 2/3+6/7 are wide-open.
#2839
Originally Posted by M. Requin
Well there we have an optimist!
#2842
Administrator - "Tyson"
Cool intake manifold for a twin screw Dodge Viper kit:
#2845
I've decided to swap the stock throttle bracket on Rocket and install the S4 setup but I need help on the Mount bracket for the S4 throttle quadrant.
No need to have the longer cables and S3 throttle quadrant. I've already got the S4 throttle cable and quadrant, just need the kickdown cable and mount bracket
Looking for info and pics of the S4 throttle quadrant mount bracket and throttle cable routing?
See pics...arrows to the S3 t-quadrant and SC t-cable to the t-body. Arrows to the S4 quadrant and SC t-cable to the t-body. What holds the S4 quadrant in place??
I can use the additional space up front and the S4 setup looks cleaner to me. Not to mention the throttle pedal stiffness.
#2846
Darien I'll look through my documentation and see if I can find any good pics of the throttle setup.
Hey I also have my first pulley bracket that you and I were discussing available for you if interested. PM me on it.
#2847
I'm just starting my re-installation of the Andy Keel kit on my 86.5 Auto and have an S4 88 manual I can pull all but the trans cable off.
I think your right it will clean up the front of the engine and won't look so out of place.
#2848
Thanks Chris!
Yea, not sure why it took 12 yrs after install to think abaout it. LOL
I think DR's kit had an update to the mount bracket that may work as well
#2849
Air filter systems for the TwinScrew
What are you all using for your air cleaner housings, and where are you locating them?
I had thought about going through the right side inner fender, but I have my Air/Oil separator in that space, as well as the intercooler pump and plumbing. (below)
I looked at modifying the 928 Motosports radiator cover air-filter and housing, but Carl's being oblique about it.
I'd appreciate any pictures of other installations.
#2850
I have my IC pump mounted back by the windshield washer (IC) reservoir.
Here is my large K&N. Had to re-position the jump post and coil.
