928 Forum 1978-1995
Sponsored by: 928 Specialists
The Twin Screw Thread
Old 04-24-2017, 03:35 PM
  #2821
hans14914
hans14914's Avatar
Nothing is ever as easy as you hope its going to be....
I finally have an idealized version of the jack shaft linkage, shaft supports with TPS and accessory mounts, and everything according to my model should fit like a glove.
Print the model, and it fits great on the supercharger. I am really liking the look.
Go out to the driveway and plunk a manifold down in the test mule, install the throttle inlet assembly and it fits! Then on closer inspection, it just barely fits. Note the clearance between the throttle shaft support and the fuel cooler.
That support cant move to any other location with the 37mm off the shelf linkage arms I was planning on using.
So, after much head scratching trying to calculate range of motion, binding points... etc I just said "screw it" (pun mildly intended) and set off to design my own linkage arms. The design challenge here is creating one arm that will work in all four locations so I can reduce the tooling and part cost.
After several attempts, I think we have a viable solution. This modular arm allows me to install a spring/stop screw. Modifying the throttle housing around the bearing gives me easy adjustment of both the throttle blade resting and full open positions independently. I have removed 7mm of radius from the arm, so I can move the jackshaft and mounts forward and now clear the pesky fuel cooler.
Progress is made when you run out of cash for machining, but still like finessing the models for that hopeful day you win the lottery.
Old 04-24-2017, 05:42 PM
  #2822
AO
Supercharged
AO's Avatar
What are you talking about? That TOTALLY fits! I think mine might actually rub in the GT! (I didn;t say that)
Old 04-24-2017, 06:10 PM
  #2823
hans14914
hans14914's Avatar
Its close, but the first time someone did motor mounts or a torque tube swap, that bracket and shaft would certainly become a casualty. It would be just fine if that monster nut wasn't there.
Seems to work ok with the shorter arms, just need to work out all the revised brackets. I had a FPR mounted back there that the shaft is now interfering with.
Old 04-24-2017, 06:35 PM
  #2824
V2Rocket
Rainman
V2Rocket's Avatar
looks like a fine place to replace the threaded fitting with a hose and clamps
Old 05-01-2017, 10:21 AM
  #2825
Chris Lockhart
Chris Lockhart's Avatar
What is the recommended crank position while pressure checking the intake/supercharger for leaks? 45 BTDC ?
Old 05-01-2017, 11:31 AM
  #2826
AO
Supercharged
AO's Avatar
AFAIK, there isn't one. Our engine don't have cam overlap, so you don't have to worry about it going straight out the tailpipe. You'll know if there's a leak right away. pump it up to about 15psi and listen and feel for leaks. Hopefully none!
Old 05-01-2017, 12:24 PM
  #2827
Chris Lockhart
Thanks Andrew.
Old 05-01-2017, 02:25 PM
  #2828
BC
BC's Avatar
I think on certain cars (GTS?) that nut is not there.
Modern cars have even closer tolerances.
Old 05-01-2017, 02:26 PM
  #2829
BC
BC's Avatar
Just keep swimming.
Old 05-02-2017, 08:27 PM
  #2830
jeff spahn
jeff spahn's Avatar
Well. I am torn. I have put real dollars in this and am about to dump more real dollars in this project, approaching 1/2 of expected retail price. If any of you are also early adopters of Hans's supercharger I would ask you to also send money to Hans to get our units off the drawing board and onto our cars. I am selling my current VCB system and am fully expecting, sooner rather than later, a hans supercharger for my S4. Perhaps we should all communicate with each other and collaborate to get this done. Feel free to contact me via private message.
Old 05-03-2017, 10:10 AM
  #2831
Chris Lockhart
That's a great idea Jeff. Wish I could join you on Han's system, but unless I win the lottery, it ain't gonna happen. LOL. It may not be the most powerful system in the world, but for a beautifully designed and crafted "set it and forget it" system, I personally think it's THE one to get. I can't wait to see some of you guy's Han's systems installed and tuned.
Old 05-03-2017, 12:41 PM
  #2832
AO
Supercharged
AO's Avatar
Hans knows what he's doing, but he's just one guy. He'll get it there. Remember the squeaky wheel gets the oil.
Old 05-04-2017, 09:39 AM
  #2833
jeff spahn
jeff spahn's Avatar
I am not doubting his ability to do what he is doing. I am trying to spur on those that are also committed, and I don't have knowledge of how much they have paid in, to send in more money and get this project finished. Once I am all in, I am expecting a system. If someone else has given $1000 and is just waiting for the end to happen, that's not gonna work. We all need to be 1/3 or more in at this point. I want to get together with the others and see what their thoughts are or how we are going to finish this.
Old 05-05-2017, 12:57 AM
  #2834
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
i think at this point we should be closer to half in.
I have another A$1k headed his way on May 10.
Old 05-05-2017, 02:56 PM
  #2835
AO
Supercharged
AO's Avatar
I'll send Hans $10,000 Nigerian dollars, if that will help.
Quick Reply: The Twin Screw Thread
