The Twin Screw Thread
https://www.youtube.com/watch?v=gd7K...ature=youtu.be
[QUOTE=Tony;11827190]448 rwhp...442 rwTQ...and after looking at a dyno video that was in 2007. I have since upgrade to 42lb injectors, Sharktuned it and improved the airflow into the MAF. I really should go get it done again...but im sure im north of 450 now??
2007.
Dariens car...it has since been well sorted out!
You can also see the custom bulkhead fittings with the sealing nuts installed. The intercooler fittings will exit the lower manifold through holes machined in the back. The nuts have a captive o-ring, and will screw tight against the rear external face of the lower manifold with some thread sealant providing an air-tight but field serviceable assembly. The intercooler can be removed for maintenance, or a basic kit upgraded to intercooled int the future.
The fittings are a standard -16AN for flow to exceed what is necessary for a 500hp constant duty. I will try two pumps and adjust as necessary, both brush-less and rated for coolant and automotive environment with extended service life. One has 3/4" hose fittings and the other 1".
Getting ever closer. Hopefully the new rails will be here next week.
Hans
<snip>
Hans
I will be working with Colin Jensan of Jensanracing.com, in Abbotsford, BC. Colin has been tuning these things with the SharkTuner for a while now, and is the Canadian distrubutor of all things JDS, up here.
Colin wants me to make a few modifications to the Andy Keel kit that I have installed on the car, the first of which is a change of injectors. He wants me to transition to the Siemens Deka4 60# injectors. This will require the fabrication of an adaptor for the smaller-diameter injector body, and the injector will now have to seal on the lower o-ring, rather than on the larger injector body. This will actually be a pretty simple CNC lathe project, so while I have the TL-1 turned on, I might just as easily turn a few sets of these things if anybody out there is interested in this modification. They will be turned from 6061 aluminum. I am thinking that they will be located by one or two 4mm bolts through the adapter flange, secured into threaded holes drilled into the Keel manifold.
The adapters will look like this, which is a 3-D printed version of the drawing below. (essentially the first-design Pizza adapter)
Like this drawing, which was the original Pizza bushing concept for the OEM style injector, when he wanted it it seal on the bottom o-ring, as the DEKA4 injector must.
Price will depend on the number of sets, but I'm thinking about somewhere around $150.00- $200.00 US for the set of 8. I could get them anodized if we can all agree on the color. Black would probably work.
This will be a one-time operation, so if you think you might want them, speak up now. PM please.
Price will depend on the number of sets, but I'm thinking about somewhere around $100.00 US for the set of 8. I could get them anodized if we can all agree on the color. Black would probably work.
As i look...your manifold is different than mine. Is your water inlet on the top?
Yes, one of the intercooler outlets is just in front of the air pump.
These are meant to replace the large rubber grommets in Andy's manifolds and will accept an OEM (Bosch) type injector or the DEKA 4 type that I will be using. [/B]
Still on the printer.
Finished.
The price that I have received from eMachine is $200.00 per set of 8, priced at one set; ~$100 ea set, for 2 sets. It comes down with each additional set. Anyone interested?
I will provide the eMachine drawings and/or the MasterCam files to anyone that wants those, as well. No Charge
Instead, I designed the bracket with a modular lower pulley in mid. I plan on making a billet crank pulley that can use the Metco supercharger drive rings. The 6.55" looks to be the perfect combination with an off-the-shelf 2.75" supercharger pulley and 2.5" alternator pulley.
It needs another evening of tweaking and re-thinking some of the hardware choices for reduced machining costs, but it should be ready to go to the shop before the end of the week.
It's difficult for me to see exactly how the belt path will be. A couple things to consider is that if possible you should have a dedicated belt for the SC. Those air pumps take quite a bit of power especially when accelerating. The tensioner should be on the loose (non drive) side of the belt. Having the alternator on the tight side of the belt puts a large load on the alternator mounting brackets and the bearings. I'm not sure the stock crankshaft multi rib pulley is strong enough to absorb the load of the alternator and SC.
Find a similar SC installation and open the throttle quickly while watching the belt and tensioner.
Louie
