Modifying timing/fuelling easily and effectively
Originally Posted by Sterling
It also seems like every week there is some new expert (who usually doesn't even own a 928) signing in trying to educate the rest of us to what we need to do to improve the performance of our cars....
Yeah, you know, you'll really have to pardon me for that man. I just thought everybody should know about that New citrus additive to the gasoline that was supposed to add 500rwhp was just orange juice.... And that it was much cheaper from Walmart and actually added 600.
But my car got the runs, so....
While I am pending an answer to "are new forum members welcome with new ideas" I'll assume the answer is Yes. So with that distraction aside, I'll repost the initial information posted so we can stay on topic, with the corrections to some information provided.
Q: Is there a cheap way and easy way of retuning air/fuel ratio [and if necessary timing] of cars when changing the intake, exhaust, fueling or combustion point [eg: exhaust, headers, boost, better-flowing MAF, firestorm plugs, water injection, etc]?
A: Here's a couple of suggestions of how this could be done on a 928.
1/ If requiring a scientific approach to the tuning process, the narrow or wideband sensor output should ideally be logged against RPM using a analog data aquisition device like the cheap DataQ [$25/50US DI-194RS/DI-148U $50US] on Ebay.
A practical example of this is shown the URLS below:
http://cyberdave.org/CarTest.html
http://cyberdave.org/carwb.html
Shareware/freeware to be used with the DataQ device is available at
http://www.ultimaserial.com/
http://groups.yahoo.com/group/ultimaserial_group/
2/ A cheaper way is to do open-loop tuning while monitoring the O2 sensor signal. Disconnecting the o2 sensor so car goes into open loop tuning [no O2 sensor correction, just using MAF/throttle position,.etc], then monitor the o2 sensor signal with a digital voltmeter for appropriate air/fuel ratio (AFR) at various different throttle positions (eg: increments of 500rpm). Adjust the MAF signal using techniques presented below until appropriate AFR is obtained. With normal plugs this may be between 12:1 - 16:1 depending on desired fuel/economy or performance. 14.7:1 being the point of minimal exhaust gas emission.
A table of O2 sensor voltage to air/fuel ratio http://wbo2.com/sw/20-tables.xls. "Nbsim" is the O2 sensor output voltage for row for corresponding Lambda and AFR presented. The NBsim worksheet providing a at a glance representation.
3/ Modifying the the timing and fuel maps can be performed a number of different methods. Three are presented below:
[i] Cheapest/easiest way way would be adjust the timing via the distributor position and adjust the fuelling curve for O2 signal and MAF signal using:
* O2 signal, for constant cruise conditions: a free mixture controller schematic is available at http://better-mileage.com/memberadx.html which changes the stoich point of a narrowband O2 sensor. Combined with water injection the author of the website claims 18% improvement in fuel economy!!
* MAF signal, for changing throttle conditions: cheap Jaycar Digital Fuel Adjuster (DFA) or or more expensive Apexi SAFC-II device on Ebay. DFA is in my opinion better as it provides up to 128 points of adjustment between 0-5V as explained at http://autospeed.drive.com.au/cms/A_2418/article.html. Available as self-build kit at URLs below:
[US/Canada]
http://www.jaycarelectronics.com/pro...Max=&SUBCATID=
$51US
$38US
[AUS/NZ]
http://www.jaycar.com.au/productView...Max=&SUBCATID=
$80AUS
$60AUS
[ii] megasquirt internet/forum developed ECU in piggyback mode using software provided. The fuel maps responding to the O2 and MAF signal. The great thing is megasquirt can be later extended to provide the ultimate tuning device: FULL ecu control of the fueling and timing, use wideband sensor input to allow self-monitoring of an AFR and can use A MAP sensor instead of a MAF. All available at a later date if comfortable in doing so. Less than $500US built. See http://www.megasquirt.info
Other piggyback or standalone ECUs are available too. Motec, Haltech, Autronic, Wolf3D. A good price/performance point being the PerfectPower SMT6/SMT7 piggyback ECU.
[iii] sharktuner to change existing eeprom ECU fuel maps. As per https://www.928gt.com/p-40359-928-sh...87-95-928.aspx
Pro: Cool idea, uses existing ECU, no wire cutting necessary
Con: bloody expensive ($1700), unless you loan out the equipment from someone. No idea of what the loan price is. Tuning limited to ECU capabilities designed a few decades ago. Also no ignition mapping abilities.
[US/Canada]
$51US
$38US
[AUS/NZ]
$80AUS
$60AUS
The MS and the Sharktuner are the only things there that are not line conditioners, barring the 25 dollar data logger.
And since you're going to repost something 5 freaking inches down from where you did the first time, here you go.
Originally Posted by chris0626
sjsj,
If you really want to modify your timing and fuel maps, the ONLY good way to do this is with a true standalone EMS. Period. And the only way to verify your 'tuning' is on a dyno, where loads on the motor can be held (speeds that would be unsafe to even try on the street while tuning).
SAFC's merely trick the stock computer and will wreak havoc with timing.
Messing with timing and fuel can result in a cleaner burning motor... more power, better fuel economy. However, going too far in any direction pushes you that much closer to BOOM! One bad tank of gas (or whatever) is all it takes.
Originally Posted by sjsj
Thank you for the warm welcome. In any case, original question remains "are new members with new ideas welcome here?"
sjsj
sjsj
Also, a note on culture. You mention "cheap" 5 times in your post. Quite frankly, the majority of people here with any interest in altering fuel/ignition maps will perform such tuning with the help of a dyno and/or a known, respected expert. When offered a "cheap" way to push the envelope, most will say, "yeah, but how cheap is a rebuild?". Answer: Not very cheap, you could blow up a couple Chevy motors or several Honda motors for the same money.
Most folks who have 928s whether they mod them or not are far more interested in doing things "Right" and value that over doing things "Cheap". IMHO there is nothing at all wrong with anyone presenting information here, different viewpoints are always welcome. I'm just trying to put it into perspective for you -- you will find a limited attention span here with regards to half-measures and/or methods that are not applicable to the car being discussed.
For example, I don't think that any of the 928s that have MAFs have distributors of a type that permits alteration of timing. I could be wrong, but if I am then cars that fit that description are the exception rather than the rule.
Under the Lift
sjsj:
You've thrown a lot of stuff out there about cheap and easy ways to do things - expect scepticism, even major scepticism. Also, you've made some statements that lead me to believe you are fishing for flame job a bit. Things like:
"* Tuning can be done without dyno and cheaply so, RE: Dataq, wideband. Easiest is using the stock O2 narrowband sensor and voltmeter." - Go read Louie Ott's extensive posts on this and tell us why he is all wet. He has tuned more parts on a 928 than just about anybody else and he has the engineering background to substantiate what he says.
"* Go too far and allow the knock sensors to kick in, no boom necessary, other than the loss of breath you get from fearing the boom whenever you turn the key." - Sorry but people with functioning knock sensor have blown up these cars. The knock sensor is not going to take care of serious detonation.
If you want to take my remarks as a hostile response and get your feelings hurt, fine. You're as welcome here as anyone else. Just understand that your somewhat cavalier, why can't people just accept new ideas presentation doesn't give you instant credibility. You may know exactly what you are doing. If so, then when questioned by us numnuts here, tell us why we are wrong rather than just get hurt.
I'm listening. If you can turn us on to some easy, cheap new ways that really work, fabulous. Don't give up if you think you are right just because you've encountered resistance. But don't just sit there and imply we are a close-minded group aiming to drive out anyone who spouts a new idea. We buy lots of new ideas for our cars all the time.
Your words, not mine. Hurt? You wish mate. Disappointed, yes, is heresay rather than any proof.
I'm listening. If you can turn us on to some easy, cheap new ways that really work, fabulous. Don't give up if you think you are right just because you've encountered resistance. But don't just sit there and imply we are a close-minded group aiming to drive out anyone who says spouts a new idea. We buy lots of new ideas for our cars all the time.
On TOPIC:
Have a read if you missed in the previous two times it was posted. A practical example of using "cheap" DataQ and a wideband sensor for DIY tuning without the need for a dyno, or fear your car is gonna blow up like that picture of a nuclear detonation, is shown the URLS below:
Results and on topic discussion welcome. Any misnomers to rules. regulations and hierachy please take offline via private messaging for the sake of other forum members, if you value open ON TOPIC communication.
sjsj
Supercharged
sj-
This is the 928 forum. If this is not specific to the 928, you should post to the Off Topic page. But you'll have to pony up the $20 or so to access. Let us know when you get your first 928.
What is different from vehicle to vehicle is the ability to tweak the existing ECU fuel map based on how locked down it is. Sharktuner being the IMHO rather expensive choice for the Porsche 928 owner to change fuel maps while retaining the stock ECU with no need for piggyback ECUs. Megasquirt or the Jaycar DFA representing much better tuning value. The DFA being more limited in it's scope [see autospeed URL about it to know what it does and it's limitations].
I do not benefit from the sale of any of such items. Simply sharing the love of cars and how to easily and convenient tweak them for maximum performance/economy, upgrade their computer management to the 21st century, without allowing money to get in the way of a learning experience.
sjsj
Hi Stirling,
You are correct, the Sharktuner does not have EZK remapping at present, this is being worked on at present. I agree that there probably won't be an Autotune facility on ignition timing - does anyone else offer that ?
Hi sjsj
If you think a SharkTuner is expensive, then you value our time very cheap ! The price reflects the substantial development time and the limited market. I will never make any money out of it to repay what we have put into it.
Hi sjsj
sjsj,
Of course new ideas are always welcome.
But, as been said before, most are not willing to risk a motor of the 928's value to 'try' something that may or may not work. A typical rebuild on a 928 V8 has a substantial increase in cost over a comparable Chevrolet or Ford V8 and the parts aren't 'quite' as readily available (you can't buy rebuild parts at your neighborhood Pep-Boys).
A real EMS is only gonna cost in the neighborhood of $2k (if you wire it yourself) and the dyno-time can be had for less than 1/2 that. A very worthwhile 'proven' investment... and a rather insignificant amount in the grand scheme of things.
Cheap and 928 are 2 things that just do not go together.
sjsj,
But, as been said before, most are not willing to risk a motor of the 928's value to 'try' something that may or may not work. A typical rebuild on a 928 V8 has a substantial increase in cost over a comparable Chevrolet or Ford V8 and the parts aren't 'quite' as readily available.
Observing it's limitations, it provided a very cool solution indeed, with minimal risk if tuning along the 14.7:1 ratio with good coolant and good oil.
sjsj
A good reason to loiter here then.
I do value the concern you place and no doubt others do too.. However, I , who could also be grouped into the "most" group, DO value such information as presented AND (as it is simply a summary of bits and pieces I've been exposed to), am aware that it is a rather inexpensive solution AND know first handedly that the DFA does work with ANY MAF equipped car.
A new idea for you: "inexpensive and SAFE tuning IS available for the 928".
sjsj
sjsj
You mentioned about tuning the A/F ratio using the narrow band O2 sensor and a digital meter while driving with the sensor disconnected from the LH. Tuning the A/F on the road while monitoring the O2 sensor is possible and you can get a fairly close max power mixture reading. You can't really use a digital meter because the reading is jumping around so much you can't readily discern the 0.02 to 0.03 volt differentiation (with narrow band O2 sensor) you need to be within for best power A/F ratio. The RPMs are changing so rapidly you can't make much sense of it to get a relationship of mixture vs RPM.. It's much better to make a run and log RPM & O2 sensor voltage and analyze later. The SMT-6 will do that as well as any number of other data loggers. Make mixture tuning corrections and try again. Simple disconnecting the O2 sensor doesn't make the LH run in open loop in any useful manner. The LH will run open loop, but it's done differently.
As for the "Firestorm", the web site is quite a hoot to read. Lots of words, but no information of any value.
Run with A/F ratio of 24:1? You could get an engine to run that lean with a compression ratio of around 18 - 22:1. They are called diesels and can burn french fry oil and need no spark plugs. They actually work pretty good.
One thing to remember is that the 928 in stock form is already tuned very close to optimum. Those Porsche engineers were no dummies. You can tune timing a little closer to the edge and extract a litttle more. Mixture tuning doesn't get a lot more power since it isn't very critical except for needing rich at the top end of the power range for thermal safety. Until you do other things to the engine to get it to pump more air, and the stock A/F map doesn't quite fit anymore, you won't get a lot of gain. Some of the MAFs are getting "long of tooth" now and are no longer well calibrated so with some tweaking of the mixture performance can be restored.
Originally Posted by Louie928
Since you know first handedly that the DFA will work with ANY MAF equipped car, I suppose you also have it figured out how to make it work on the 928. The 928 MAF outputs more than 5 volts, and unless I misread the data, the DFA does not. In fact of all the fuel injection tuners you mentioned, I don't believe any of then put out more than 5 volts except the Perfect Power SMT.
The DFA allows +50% and -50% adjustment of a signal at any of it's points along it's range. The only thing it doesn't do is invert the signal if you are for instance mapping 0-5V to 5-0V, as is the case for me changing from a AFM to a MAF, yet the ECU still requires an AFM type signal. I'm playing with my DFA to do this.
sjsj
Captain Obvious
Super User
Super User
The DFA can be considered a general purpose voltage remapping device. It works within 0-1V (so can modify an O2 sensor signal), 0->5V and 0->12V range as per article http://autospeed.drive.com.au/cms/A_2418/article.html . From my experience it can also be set to intermediate ranges such as 0->6V for instance by changing the adjusting the onboard adjustable potentiometers.
sjsj
sjsj
I have this weird feeling that you have been kicked out off other boards for acting like a "know it all".
Keep mentioning the that you have first hand experience with some of these products. Tell us more about it. About the engines you built and not the shamelss plugs you keep pushing here. Let's see that resume of yours!
