928 Forum 1978-1995
Sponsored by: 928 Specialists
Running Rough (HELP!!) Conclusion!!
Old 11-09-2005, 10:46 PM
  #61
NickT
NickT's Avatar
Originally Posted by FlyingDog
Were they the wrong heat range, gap, material? From what I've read on Rennlist, 928s don't like platinum plugs. They should be Bosch or NGK copper.
I have a similar thread regarding my '88 running rough. I had platinum plugs for 5 years and not a hint of problem. When my rough running started I did the basic tune up including putting some AutoLite coppers in (They were out of Bosch and I was impatient). Fixed the rough running. Put the Platinums in, ok they were 5 years old.. and the car ran like doo-doo again.... But, not to keep me happy for long... Now I have an idle surge that is driving me to drink. Nice bottle of red last night
Old 11-10-2005, 03:16 AM
  #62
Darien
Darien's Avatar
Thumbs up Hat's Off!!!
I'd like to take a moment to thank everyone involved in helping me trouble-shoot my ignition problem.
https://rennlist.com/forums/showthread.php?t=235640
A special thanks to Henry and Tony for taking time out of there busy schedules to let me swap parts during the isolation phase
It's great to have experienced folks help out during a time of need
Old 11-10-2005, 10:30 AM
  #63
NickT
NickT's Avatar
What was the final conclusion?
Old 11-10-2005, 12:56 PM
  #64
Darien
Darien's Avatar
It's looking like bad plugs. I installed the BOSCH Platinum Plus 2's back in Apil, they had approx 7K miles on them
Old 11-10-2005, 01:42 PM
  #65
AO
Supercharged
AO's Avatar
Darien- I'm glad to hear that you fixed your issue. You should still check to see if you see sparks from your wires - because you shouldn't.
Finally, as a service to the rest of the patrons on this forum, as a jet mechanic, can you please tell us what airline you work for?
Tony- Ever thought about a different profession?
j/k
Old 11-10-2005, 01:45 PM
  #66
Bill Ball
Under the Lift
Bill Ball's Avatar
Interesting. I've run platinums and copper and not seen any difference over 20-30k miles, although many others here seem to find fault with the platinums.
You did have some bad wires too. Even your new set had some dancing lights at night. Is that resolved?
Old 11-10-2005, 01:47 PM
  #67
heinrich
928 Collector
heinrich's Avatar
Plugs are not bad, just fouled. Wires were the cause.
Old 11-10-2005, 07:07 PM
  #68
Darien
Darien's Avatar
I checked plugs first and they looked fine, hell, it may have just been the #4.
While checking all connections and vacuum lines, we discovered the Nology Ignition Coil AMPS leading to the Coils. Not sure if one or both of them may have contributed to my problem.
Andrew, not sure what you meant, but I've got over 17 years in the USAF and have worked over 50 different aircraft. The Shark is not a JET!
Old 11-10-2005, 11:24 PM
  #69
Tony
Tony's Avatar
Depends which one you ride in
The way things are going Andrew, i may have to...33.5% last dec...probably another 19.5% this dec...Were all gearing to walk the picket line..
I was hoping the NWA guys would hold there ground a bit more
Old 11-11-2005, 08:53 AM
  #70
AO
Supercharged
AO's Avatar
Just teasing you a bit...
That's rough, but we're feeling it too. Wife just got hit 22% yesterday, plus all internationals now have foreign (read Chinese) based FA crews. D. Steenland, CEO of NWA, was one of the principals at Eastern when it went down, so I don't hold a lot of confidence in his abilities.
The good news is that deer season opens tomorrow (I think). Maybe we can live off the land - like Grizzly Adams! Or maybe we should just drink ourselves into oblivion... What was I saying? *hic*
Old 11-11-2005, 11:16 PM
  #71
kgrimshaw
kgrimshaw's Avatar
Default Rough running
Darien
I just read the end of the thread and thought I would share my two fixes of the same problem you are having (sorry if this has already been suggested).
The first fix was a bad crank postion sensor. The sensor is located on top of the bell housing. When this unit went it was just the lead wire shorting out on the bell housing and it caused the shark to some times run rough, not at all or perfectly normal. I had replaced all of the ignition wires, coils, plugs trying to diagnose.
The second was an open circuit 02 sensor. I actually had a mechanic diagnose a bad cam. I didn't believe him and thought I would try the o2 sensor. Finally, all was well.
Old 11-12-2005, 09:27 PM
  #72
cambria
cambria's Avatar
If your car starts running on less than eight, and you are smelling fuel, you could be dumping raw fuel into the cat. coverter and a fire could follow.
Old 11-12-2005, 09:29 PM
  #73
FlyingDog
FlyingDog's Avatar
Naw...
Quick Reply: Running Rough (HELP!!) Conclusion!!
