meanwhile, back at the professor's laboratory...(Ott fender flares)
#51
Rennlist Sponsor
Originally Posted by Sterling
the GTS Quarter Panels are still available.
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
#52
928 Collector
I think the work is so extensive that unless you spend the $$ it would cost to buy another 928 you're going to have rust and rain leak issues if you instal GTS quarters. The Ott flares are basically bolt-ons and they don't come near the windows or seams which is great.
#53
Plus swapping out the 1/4 panel has a book labor time of about 25 hours EACH ! and you need the special GTS curved gas door at about $200 from Porsche.
#54
928 Collector
JimB, it's a good thing the GTS shares so many components with its predecessors or it truly would be exclusively a rich man's car, because its parts would all be astronomical. At least only some are .... I'm glad i didn't buy a GTS when I had the opportunity, because it would have precluded me from so very much I have been able to do with other 928's. If I had more money that would not even come up as a question
#55
Rennlist Sponsor
???? A quarter panel change is very common and child's play for a body shop. There is no more chance of leaks or rust than with a stock original panel.
Strange, the last set of factory quarter panels I sold were installed and painted by the body shop for under $900. I think that book labor rate could have been swapping in used quarter panels. The labor needed to just prep (not installation) used quarter panels cost just as much as installation of new ones that don't need prep according to the body shops I have worked with..
#56
928 Collector
DR, maybe body work (like women) is a lot better in North Carolina. I assure you here, it sucks. Unless you pay. I once took my 944S to a body shop with an excellent reputation (we're talking 8 years ago) and the quote to simply repaint the removable sunroof panel, was $760.
#57
The Mitchell book rate was new panels but was installing the full panel breaking all the spot welds around the 1/4 window ,going to the roof , all around the rear bumper cover. Some body shops might opt to cut and splice which would greatly reduce the labor. Here in California you would be lucky to get two 1/4 panels painted for $900
#58
Rennlist Sponsor
FYI, that was done in Atlanta by Automaster Precision, one of the best in the business, not a "redneck NC body shop in the basement" type place :-).
#60
Rennlist Sponsor
Weird, with the proper spot weld drill bit , you could remove a panel in an hour or so ???
I would think that cut/splicing would take longer than drilling the spots welds and then using a spot welder to corectly put the quarter panel back on.
You guys are getting gouged big time!!! :-)
