84S Starts, Dies Twice, then No Start
#31
Dan, is it a twin-distributor S? If so check the belt that drives the forward distributor. If it's a single, check the green wire. If you don't have spark, run through this checklist.
#32
1 Post
Will go thru the list in the days to come and on the weekend.
#35
1 Post
Update...Fixed
Today, checked the infamous green wire....wigle here wigle there, seem's snog and solid, wire looks fresh...No start.
Decided to go back and "play" with the relays.
Swaped XVII with XV... start & run for 10 sec, click sound from relay stoped.
Swaped XV with XVII... no start
Swaped XVII with XV... no start
Swaped again and bingo; start & run run run run......
Conclusion!? Bad contacts/oxidation from the humidity of winter storage?
Note to self : clean contacts thuroughly(sp)
Thanks for your help.
#37
1 Post
French swearing OSTI DE CALISS DE TABARNAC
It's doing the same thing again.
I had the time to do some shopping and when I was ready to leave for work, it died in the driveway.
Will bring all relay to my collegue at work who is an electronic tech.
He will check them for me.....
Will keep you posted.....
#38
Under the Lift
You might make some short jumper wires you can use to jump 30-87 in the relay sockets. BUT since your problem appears sporadically, it may be hard to discern which one is bad by trial and error, so having somebody examine them is a good idea. Once might have a burned contact point.
#39
I had a problem similar to this with my 88 S4. Turned out to be a bad connection in the fuse panel. I was able to pull the wires out and solder them up properly and the problem went away and hasnt been back since. Pulling the panel was easy, as was putting it back in, but damn is it scary!
#40
1 Post
I will get him to check my FI relay (XVI) as well as the pump (XVII).
#41
1 Post
Update...sunday june 14th 13:05
Here are the values I have so far : red are my values, black is supposed values
Battery : 11.80v
Post : 11.75v
Fuse panel : 11.55v @ relay plug
Test #5 from WSM : Resistors & Coil test
Resistor : in car & bench test (OHM)
0.4 ohm res. : 0.7 (0.35 - 0.45)
0.6 ohm res. : 0.8 (0.55 - 0.65)
Coil : in car & bench test (OHM)
Primary terminal 1 & 15 : 0.7 (0.33 - 0.46)
Secondary terminal 1 & 4 : 9.2k (7k - 12k)
Guess I need new resistors and coil!?
What you guys say?
Battery : 11.80v
Post : 11.75v
What you guys say?
#44
It could, proper voltage is key to your car. It could also be a sign of a possible alternator failing or being very weak or poor connection. Those can certainly cause erratic symptoms as well as no starts and dying.
