928 Forum 1978-1995
Sponsored by: 928 Specialists
Stuck Throttle (in the Mountain Twisties, no less!)
Old 10-03-2005, 11:34 PM
911Dave
911Dave's Avatar
A stuck throttle shouldn't be a dangerous situation, should it? Just immediately shift into neutral and turn the engine off. Leave the key in the "on" position so you're steering column doesn't lock. No puckering required.
Old 10-03-2005, 11:40 PM
Ed Scherer
Ed Scherer's Avatar
Well, it kind of depends on the situation. At low revs, probably no big deal. At WOT, though, I wonder what would happen if you immediately take the load off? And to further complicate matters, if you're in a location where you can't get off the road without doing damage (like rock walls or ditches), you're going uphill, and it's full of blind curves and stuff, you really don't just want to stop on the road.
Under most other circumstances, you're right -- it probably wouldn't be all that big a deal.
Old 10-03-2005, 11:44 PM
sublimate
Gluteus Maximus
sublimate's Avatar
In real life I'm sure there's usually plenty of puckering as it'll probably catch you off-guard. Also don't put it in neutral first as you risk overreving the engine, just shut it off and then take it out of gear (unless you need the engine braking). But be aware that you'll instantly lose your steering power assist and may lose your power brakes (probably not right away, but don't dwadle).
Old 10-04-2005, 12:01 AM
BC
BC's Avatar
If you look at the sheeth part of the throttle cable you will see a part number (I'm holding both of mine in my hand). Replace that piece by whole I would suggest. Those litle plastic thingys are the dangerous piece at the ages these cars are. Thats what sticks. Also, on S4s, there is such a convoluted manner by which the throttle movement happens, it could be the wheel thing under the intake filter for the engine.
Originally Posted by Ed Scherer
Thanks for the replies so far, guys. Still waiting for answers or comments on some of my original questions, though. I'm getting a lot of answers (and entertaining related stories!) to question 1, but nothing on the rest.
  1. Has anyone else experienced a stuck throttle like this? Did it take anything beyond just lubricating the ball/socket connections? Any preferred lube? (keep comments coming on this one, if you'd like, but you've already told me a lot on this one)
  2. Note that the little rubbery, amber-colored, conically-shaped guide that used to be on my accelerator pedal cable split into a few pieces and eventually fell off (see the second photo below for the remains). Is this an individually replaceable part? (Hard to see how you could replace it unless it's really stretchy, unless you recrimp the end of the cable). Is this an important part? Is there much of a risk of increased wear (or sticking cable or something) if I don't replace it?
  3. Note that the black plastic, conically-shaped guide that used to be on my A/T kickdown cable is also broken off (you can still see a little fragment of the remains, though). Is this an individually replaceable part? (Again, hard to see how you could replace it without recrimping the end of the cable). Important part, or not? Risky to run without it, or not?
  4. Generally, what is the condition of these guides on your car? The remaining guides on my car look like they're not going to last much longer. Starting to split and disintegrate.
Old 10-04-2005, 12:05 AM
BC
BC's Avatar
Whaaaaawawawawawawawaw.
Thats reving to redline, then bouncing back and forth between 6000 and 6500rpm.
Old 10-04-2005, 08:24 AM
Malibu310
Malibu310's Avatar
The actual problem we had in the Yellow Beast was a frayed throttle cable which had almost 100,000 miles on it... lesson: Replace the cable if you have a lot of miles to be safe.
Old 10-04-2005, 12:30 PM
Dave Howerdel
Dave Howerdel's Avatar
Follow the path of the cable from the quadrant around the pulley to the body. There is a bracket right next to the pulley that can catch the cable if there is any slack.
Old 10-04-2005, 01:14 PM
SteveG
SteveG's Avatar
On my '85, last winter, had the radiator hose off, the one to the right as you face engine. When I put the hose and clamp back on, probably for a better angle, I positioned the clamp further toward the top of the hose -- looked OK. After I started it, I blipped the throttle, it went near WOT and stuck. What a beast, scared the crap out of me. Cut the engine with key and went to look for WTF happened. That hose clamp will bind the throttle socket if it isn't just so. We always look for stray wrenches and loose connections, when starting up, right? Lesson -- after moving stuff or removing anything, check that moving parts do not bind, especially something like throttle linkage.
Quick Reply: Stuck Throttle (in the Mountain Twisties, no less!)
