Stuck Throttle (in the Mountain Twisties, no less!)
A couple of weeks ago, I was driving the twisties in and around Estes Park, Colorado (see post .html in "Best Roads In America for the 928" thread for general comments on that great trip).
Anyway, my throttle stuck three times :eek: (including once with my wife in the car) while driving these twisties. Rather high pucker factor. Especially the last time, which was at WOT after having reentered the road (from a turnout; stopped to take some photos) in front of some traffic. It's remarkably hard to haul the car back down to a stop when you can only leave the road at the next available turnout (which aren't very closely spaced). Didn't want to cut the engine too early, either, since I didn't want to get caught going uphill with nowhere to pull off. So... the torque converter got quite a beating. I'm about 99% sure I finally figured out what was going on the third time it happened (the other two times, it "fixed itself" shortly after stopping). The third time, however, when I popped the hood and took a look, I found the socket at the end of the throttle body cable at a strange angle. It was stuck at that position (see animated photo below); a little pressure, though, popped it down into the proper position again and I was good to go. Luckily, the previous day, I had the foresight to put a small container of oil in the car. Lubricated this ball/socket and it has been fine ever since. But... this episode had me thinking about doing some preventive maintenance on these cables, guides, and the ball and socket connections. Some questions for those of you that might have had similar problems (or might have some of problems similar to what I'm about to describe):
http://www.ed.scherer.name/Porsche_9...ables6Anim.gif The guide (or whatever it's called) that broke up and came off the accelerator cable end: http://www.ed.scherer.name/Porsche_9...eGrommet2a.jpg One of the "surprise stops". Couldn't just stop anywhere (lots of blind corners, so not wise to stop in street, but no shoulder either). Couldn't just shut down engine, either, because I was going uphill. So, had to time a pull-off, shutdown just right. http://www.ed.scherer.name/Pictures/...mages/2-17.jpg |
Sorry, I don't have any advice for you, but I do have to say kudos for the snazzy animated gif of the problem. Man, you're taking this to a new level. Good luck.
Actually I can add a little advice if you need it - I have a trick for lubing your cables if you want to do that. |
Originally Posted by Ed Scherer
[list=1][*]Has anyone else experienced a stuck throttle like this? Did it take anything beyond just lubricating the ball/socket connections? Any preferred lube?
Lets say it bounced off the rev limiter in a blink of an eye many times before I got the key off. A fix? I oiled it, and it didn't happen again. |
Ed.........from your great animation perhaps your inner accelerator cable is sticking. .....why else would you have that slack on the throttle body cable?
I removed all cables from the plate, lubricated the ball ends with molibdium disulphide (graphite grease) reassembled and adjusted slack per the WSM. To test any of the cables for sticking after removal from the plate manually move the cable back and forth looking for any binding. If you find any you can buy a cheap device from the local m/cycle store that clamps to the cable end allowing attachment of a spray nozzle tube. Spray the culprit cable first with WD40 or equivalent to get it clean then spray in the cable lube; should also be available at the m/cycle store and you should have good as new cable. Remember and put a rag at the other cable end if its going inside the car othrewise you end up with a little puddle of mess. |
Had it happen on my car - after I had mounted the supercharger! It was my fault but still scary!
Had it happen to me on a busy main street. Stupid me, I had blipped the throttle to give bystanders some engine music. The engine got stuck in WOT, so I literally shoved the brakes to the floor and pulled over as soon as possible, which was a few blocks away :eek: .
Same exact thing: the connector was binding as you've pictured it. I gave it a healthy shot of WD-40 and it never happened again. :cool: I about soiled my shorts on that one, especially when I had to navigate between 2 parked cars on each side of the street with another one coming from the opposite direction. I ended up playing a game of chicken with the oncoming car without the ability to stop :o . Thankfully they pulled over at the last second and let me through, flipping me the middle finger.http://64.27.21.61/forums/images/smilies/boid.gif |
On a related question. Is that entire assembly available from one of the Big 3? Mine is not very good looking and I would really like to replace it altogether.
Rob |
Rob..........the plate assembly can be completely disassembled. Remove the cables and the circlip from the end and all should just pull off. Clean, lubricate reassemble, attach ball ends and reset cable slack. If required lube cables as noted above.
I had mine Zinc plated or silver cadmium or something - and I was planning on replacing the bearings. Gosh, I need to do that soon...
Originally Posted by BrendanC
I had it happen on a side street, in FIRST GEAR, WHILE FLOORING IT.
I do hate to think about what would happen if someone else (like my wife) was driving at the time. She has only driven the shark two or three times in six years, but this might just keep her from ever driving it again!
To test any of the cables for sticking after removal from the plate manually move the cable back and forth looking for any binding. If you find any you can buy a cheap device from the local m/cycle store that clamps to the cable end allowing attachment of a spray nozzle tube. Spray the culprit cable first with WD40 or equivalent to get it clean then spray in the cable lube; should also be available at the m/cycle store and you should have good as new cable. Remember and put a rag at the other cable end if its going inside the car othrewise you end up with a little puddle of mess. Seriously, sounds like some good advice, there. I hadn't heard of the cable lubrication device you mention. Sounds like a great idea (one of those things that you think should exist, but you're not sure if it does.) I'll see if I can track one down. Sounds like something I could use for all sorts of stuff (bikes, etc.) Thanks!
Thanks for the replies so far, guys. Still waiting for answers or comments on some of my original questions, though. I'm getting a lot of answers (and entertaining related stories!) to question 1, but nothing on the rest.
Your throttle stuck open in the mountain twisties?
Some people have all the luck! |
You think you had it bad?
https://rennlist.com/forums/928-forum/169713-update-on-two-renegade-hybrids.html
Originally Posted by Malibu310
Our Yellow Blower Motor 928 setup (www.rhsdplanning.com/porsche.htm) was in an accident. In my neighborhood at 20 MPH, I blipped the throttle (a quick jab) and the linkage stuck wide open. Since the 550HP and 550 lbs of torque were instant, within the two seconds it took to reach for the key to turn off, we (my wife and I) launched 400 feet sideways through two sets of curbs at a spped I cannot even describe. When we blew through the "dead end" sign which poked a hole in our gas tank, the car did a 180 in less than 25 feet. Amazingly, the only damage was to the tank, a lower right rear control arm, all wheels and tires and some minor body damage, attesting to the strength of the car overall. No one got hurt (another miracle). Some front lawns need to be replaced next spring. It seems the problem was traced (a repeatable problem) to a defective bearing in the throttle linkage. This car will be repaired (with a different linkage setup) within a month, but put up for the winter.
Ed: All I have to say is I'm glad you are alive to tell about this!
https://rennlist.com/forums/showthread.php?t=169713
Throttle cables have been lubricated. And tonight, in order to maintain the perfect balance between car and driver, I have also been lubricated -- with some DAB (Dortmunder Actien - Brauerei) and Paulaner Oktoberfest Märzen. And Paulaner is the best brewery in the world. |
