There's GOTTA be a cheaper solution.... rattley windows
Deer Slayer
Originally Posted by kraabel
Thaddeus -
When you get around to doing it, let me know. I'll order the parts too and we can set aside some weekend to swear at our cars together. I did the moleskin trick, but it doesn't solve the rattle when the windows are down. It's definitely a guide issue.
Going to be awhile though because I am tapped $-wise out for 928 stuff... spent too much on the steering rack and motor mounts this week.
Nicole is right (of course). The guides have more to do with the window rattle when lowered. Dan Brindle has a guide to replacing them. They aren't real inexpensive either. You can try to shim them, as he describes. I replaced mine, but the windows still are completely rattle-free. Here is Dan's great guide.
Dan's Door Window Guide
@jerybak -
The link below has a written description of the process. I've checked archive.org (which is a wonderful resource if you've never used it before) to no avail.
http://www.nichols.nu/tip095.htm
I'd rather have nice quiet working windows and a nice quiet picnic
Chronic Tool Dropper
Euro S motor makes the windows rattle? Solution is still the same. New plastic guides and new felt will usually take care of it. Window rocking under the 310hp accelleration particularly in the lower (manual trans) gears supplied with that engine, that may require the rollers that Mark mentioned.
That $37 pad cost? You should have bought spares ten years ago when that was the price.
There's some good guidance on the plastic guides that slide on the guide rods, around fitment and not overtightening the screws.
Clean the little gearbox on the window motor, getting the old cake of wax out of there and replacing it with some good grease. Easy WYAIT, makes things a LOT smoother and faster.
Whenever a link is dead, sometimes waybacktimemachine is your friend...
http://web.archive.org/web/200806100...ndow_frame.htm
Oh, wow.
That's great. Dan the Pod Guy's site went down after he died.
It had lots of great stuff, especially interior stuff (doors, sunroof, that sort of stuff).
Glad to see there's a way to get to it.
Thanks.
Thanks.
