There's GOTTA be a cheaper solution.... rattley windows
Deer Slayer
My windows rattle when they're down. A lot. Thunk, clunk, clunk. It makes me mad.
There are these felt window guides in there. Mine are 20 years old. They are not soft and pliant. I need soft and pliant window guides to make the clunk go away.
You need 2 sets of felt guides per door.
That's a total of 4.
THEY ARE $37.00 APIECE!
That's a real kick in the gazoozie. Is there a way to replace these without spending the price of dinner for 2 at a five star restaurant?
Has anybody come up with a way to fix the old ones?
cheers
Thaddeus
cheers
Thaddeus
I've heard of some who've recovered the existing felt pads with new material, felt, presumably, glued right on top. I've not done it myself, so I cannot vouch for the method.
Cottage Industry Sponsor
Thadeus: Your rattle might be worn out plastic window guides - the ones that guide the glass up and down the metal rail in the door. That's what it was on the drivers side of my car (which has a lot less years/miles on it than yours. It's a nice restauration project, and I highly recommend to do the lower window seal at the same time.
Under the Lift
Nicole is right (of course). The guides have more to do with the window rattle when lowered. Dan Brindle has a guide to replacing them. They aren't real inexpensive either. You can try to shim them, as he describes. I replaced mine, but the windows still are completely rattle-free. Here is Dan's great guide.
Dan's Door Window Guide
Thaddeus -
When you get around to doing it, let me know. I'll order the parts too and we can set aside some weekend to swear at our cars together. I did the moleskin trick, but it doesn't solve the rattle when the windows are down. It's definitely a guide issue.
The Parts Whisperer
A common cause is the $6 roller at the end of the regulating arm. Roll your window down half way and see if you can rock it fore and aft. if so you probably need a new roller.
The Parts Whisperer
Originally Posted by Randy V
Is it simple to change out, Mark?
