Engine mount esoteric-a
We know the Ford '90 Bronco mounts are 3mm shorter than new Porsche mounts costing upwards of $240 ea. What, I wonder is what is the squat distance difference between the Ford and stock Porsche mounts? Is it the same? Is the orifice the same (if there is a orifice in a hydralic mount)? Is the dampning the same? All the mechanics* I talked to said they would never recommend the Ford mounts to a customer, but would give them a try for their own cars. Is it possible the Ford mounts and Porsche mounts are made by the same non-german mount maker?
*make their sole living working on cars, not necessarily Porsches.
Some folks have made up the 3mm difference with a washer, others didn't bother.
The engine and chassis ? - now smooth as silk ......
The detailed configuration of the two mounts is noticeably different; however, not in a manner to effect function: clearly from different sources.
Pressure washers can cause all sorts of problems.
Carb cleaner works great for that too, but is obviously a bit more pricey than water, lol.
Just make sure you're in a well ventillated area, and don't light a match till the fumes clear...
Is it the same?
squat distance; Not comparable between the OEM and Anchor mounts. The hydraulic mount will have less squish initially, but will have more squish later.
No orifice on a solid rubber mount.
Damping will be different, the rubber mount will transmit slightly more low order vibration than a NEW hydro mount. The Porsche has very little low order vibration, so it's seems that it's not an issue.
Maker for the two mounts is not the same. There are probably 5-7 makers for the Anchor 2698. The Porsche OEM was speced by Porsche for the car, and a certain number were made for production and refurb. If Porsche had a demand for more mounts, they would remake them from the same material. the Anchor mount also fits other cars, other trucks. They are vicariously made in China, India, Mexico, Taiwan, and USA.
I would(and have) avoided the China made mounts due to the materials used for many Chinese products lag far behind the materials from other countries. Steel that isn't Steel(pig iron), rubber that isn't rubber(molded plastic goo), etc. Just one man's experience, YMMV.
Doc 90GT in resto (with new Anchor mounts)
..... the Anchor mounts are available in two flavours, hydraulic and solid: The units I had installed were the #2698HDY (hydraulic). I suspect that this would represent >95% of the sales for 928 applications. A few have noted opting for the solid #2698 for special reasons - like heat concerns when running headers, never again wishing to deal with collapsed mounts, masochistic towards vibration, ..
I do have issues with masochistic tendendcies to do the job over again.....
Doc
