Installed a Kickdown Switch
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
My 4-speed auto was feeling a little lazy, so I installed a parallel kickdown switch yesterday. Can you say "Dr. Jekyll & Mr. Hyde"?
I was under the impression that it would just hold each gear a little longer while under mild throttle (maybe 4k RPM while at 30-50% throttle), but it seems to hold each gear (well - 1st and 2nd at least) all the way to redline.
Does anyone know what other factors are considered (e.g., throttle position, load, etc.) in determining an upshift?
Thanks!
Thanks!
Steve
So with the switch "on" and about 1/2 throttle..it will hold 1st and 2nd all the way to redline, even at the 1/2 (or less) throttle? I thought it was just supposed to make the kickdown happen faster, especially in less than full throttle situations? Maybe your bowden cable is too tight? Did the trans shift/kickdown normal before the parallel switch?
Brian
Brian
Originally Posted by IcemanG17
Steve
Brian
Brian
Originally Posted by Tony
cool picture!
do you have any more of the 4spd guts for giggles
I'm putting the new side plates on the intake soon. Louie says that my 1st torque peak will come on real strong. Ahhhh, I can smell fresh parts on the way.
My big speeding ticket was dismissed. I'm back!
Steve
Brian
Brian
Hmm, in my 3 speed 79, under partial throttle 50%-75% I usually go all the way up to 4000-4500, but to get it to kick down by itself once its changed up at anything like above 3000 it's usually a fairly heavy push on the throttle. However later MY will behave very different, being a 3 speed mine always starts off in 1st, unlike later MY AT which start off in 2nd. If I hold it in 2nd and take the revs up to a decent level (say 3000-4000 again) and take my foot off the gas it will do as yours and seem to go into nuetral and idle around 800, leaping up as soon as I put my foot back on the gas, so in that way it is identical.
Don't know if this helps much, being a much earlier MY.
