928 Forum 1978-1995
Sponsored by: 928 Specialists
Digital instrument cluster
Old Dec 9, 2004 | 10:49 PM
byrdman454's Avatar
byrdman454
Question Digital instrument cluster
Has anyone installed 1990 and newer instruments into an older 928? Is it possible? How do you do it? Is there a way to change the digital odometer to match the original mileage?
Old Dec 10, 2004 | 10:12 AM
ColinB's Avatar
ColinB
Mike
The digital instrument cluster is significantly different to the previous version. It would involve a major rewiring job to do the conversion and several associated systems would have to be replaced. Almost certainlty it would be cheaper to replace the car! The reading of a NEW digital odometer can be set to match the original mileage but a used one with more than 250 miles on it cannot be changed.
Colin 89GT
Old Dec 10, 2004 | 06:11 PM
SharkSkin's Avatar
SharkSkin
Don't the later speedos get their pulses from the ABS controller, rather than the tranny? Different number of pulses per rev IIRC.
Old Dec 10, 2004 | 06:18 PM
Jim bailey - 928 International's Avatar
Nope ,Nope, and Nope ......the mere thought of it makes me want to run screaming through the warehouse pulling out handfuls of my hair Besides the digital dash was a BAD idea even when fitted at the factory ! Who needs a $3,000 instrument cluster ?? They built the central warning brain into the multitude of circuits inside the cluster as I recall.
Old Dec 10, 2004 | 07:15 PM
BC's Avatar
BC
As I recall, the inputs are all normal except for the gas mileage readout, which uses Injector Pulsewidth to figure the numbers. John Speake corrected me on this, though, so check with him. I'd say its doable, but thats me.
Old Dec 10, 2004 | 07:32 PM
Like I said the central warning brain which was under the left foot dead pedal is now inside the cluster so all of the warning signal wires which used to go to the dead pedal area now go directly into the cluster. The wiring is significantly different. Could it be done? yes Should it be done NO and how long would it take ?
Old Dec 10, 2004 | 07:35 PM
Richard S's Avatar
Richard S
Sounds like Sterling has a new project.....would be ironic if it turned out more difficult than his vario-cam engine!
