A/T FlexPlate Problem - Need Help
After losening the coupler bolt, the flex plate moved back only 1/8". There is still about an 1/8" deflection on the flexplate.
What does anyone recommend? Should I just tighten the coupler and hope for the best or does anyone know of a way to further remove the deflection in the flex plate? Would leaving the flex plate as is and torquing the coupler leave me at a higher risk for a thrust bearing failure?
It seems to me as though the flex plate has permenently deflected to this position because the coupler was completely loose.
Nows a good time to check the crankshaft end play to see if the engine thrust bearing is also shot.
Chris
My gawd!!
Give the guy some hope will ya!
Also check to see that the rear pinchbolt is torqued to spec. I recently did a post on this ---- too lazy to find it though.
From what I have learned, 1/4" is not a complete diagnosis of TB failure. Remember it also matters how long it has been sitting that way. Still, check the crank endplay. If it is out of spec, button it up like a terminal cancer patient and drive the thing until it gives up the ghost ......IMHO
The idea behind loosening the pinch bolt on the flex plate is to eliminate residual tension: The flex plate is almost always found ( for the first time observer) to have advanced along the prop shaft towards the engine for 2-4mm: As the crank end float is of the order of 0.15-0.6mm in a healthy engine, it is obvious that the crank is under a residual tension that is pushing it ahead against the rear face of the thrust bearing.
Usually, this is of no grave concern - as long as the crank end float is as specified as above.
Therefore, it is highly advisable to do as you noted in your first post: loosen the pinch bolt, and let the flex plate relax to its neutral position: If I were concerned that it had not relaxed completely, with my own car, I would leave the bolt loose and run the engine a bit ( wheels elevated, etc). Next, I would measure the end float, attempt to center the crank within that 'float' - and torque the pinch bolt to 65 ft/lbs.
I would NOT crowbar the flex plate backwards and then clamp down the bolt - for this will serve to leave an identical, but reversed tension on the crank. Let the plate find its own center.
Regards measurement, I have no idea how you can get 1/4"
=6.4mm. When I measured mine from the edge of the flex plate collar to the machined 'ring' on the beginning of the shaft taper (to the splines) - the released amount was precisely 3.15mm. After 12 months, and the loctite 290 procedure, it has not moved at all, nada, zero!
I would not know that unless a precise measurement had been taken and recorded. Good luck.
Since the crankshaft has a tendency to want to harbor itself at either end of the end play, you really need the dial indicator to center the crankshaft before tightening the pinch bolt, however if your torque converter bearings are shot, it really doesn't matter, cause the spline won't stay in one position for very long.
The reason your flex plate became compressed is due to the spline moving forward on the drive shaft. What's not obvious, is why this happens. Elastic torsion of the shaft does not elongate the shaft length, however:
As the torque tube bearings wear out, excessive clearances allow the driveshaft to vibrate off-axis. The torque converter bearings are deep groove bearings, so when the shaft and it's bearing race hits the ball and apposing race, impact forces are transmitted axially causing the shaft to vibrate. The torque tube bearings could also create similar forces, but the rubber mounting significantly reduces there impact.
The forward spline, being attached to the flywheel by spring action has more resistance to movement in one direction than the other. The pinch bolt provides sufficient clamping to prevent relaxation of any built up pressure.
