Poor running after pothole encounter
#61
Team Owner
ground wire should go to the bolt on the rear of the cam cover on the 5-8 bank,
and the lifting lug on the 1-4 bank ,
and then to the bolts that hold the coil clamps
#62
#63
The chassis is the earth and as long as you have appropriate connectivity to it how it is effected is somewhat academic. Many smaller connections are grounded to the block but the block is gounded via its adequately sized strap. Same for the battery negative post.
#65
Team Owner
so you put different chips in the computer then hit a pothole,
and then it started running bad.
I would say that its quite possible then the chip could have come loose,
or that this should be returned to a stock configuration to rule out the chip.
#66
#67
Do you have a fuel pressure gauge you can put on the PS rail? The pothole got the PS rear, right?
So, maybe a connection to the fuel pump or weak ground back there?
#69
As well as fuel, air, spark, compression; they all have to happen at the proper time.
How's your timing belt tension? Could it have jumped?
Others on here more knowledgeable than I would know if that's even a possibility.
#71
Ok guys. I’m at a loss. Changed the chip back to the original and checked the fuel pump wires. No visible issues with wires. No change in the way it’s running. Any othe suggestions?
#72
#73
I still would like to get a reading on the fuel pressure to rule that out.
#75
