What do I torque the water pump bolts to?
Deer Slayer
I searched, and found confusing stuff about 6+2, some other values, I'm confused.
What do I torque it to? In English? Version for dummies?
Thaddeus
Thaddeus
the default when not specified is 6 plus 2 Nm or about 6 ft lbs for the 6 mm bolts , they really are not very tight . But when you have 13 bolts holding the pump to the engine they do not need to be very tight .
Originally posted by heinrich
How often does one have that rare opportunity
moohahahaha
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
BTW my manual says 6 + 2 nm for M6 engine bolts...
Test your torque wrench before tightening waterpump bolts. I had previously used mine to tighten the head bolts and although I changed the setting it decided not to click. Hence I overtightened all the waterpump bolts and then broke one of them. Luckily Jon928se came to the rescue again and managed to remove the broken bolt remains without using an extractor.
Now I test my torque wrench to make sure it clicks before tightening any critical bolts.
Deer Slayer
Thaddeus, DiamanteBleu is French I'm assuming ... my Diamond Blue Metallic S4 was "Diamantblau Metallic" in German .... Since I'm on a roll
Sorry for the dumb question but, doesn't 6+2=8? Am I correct in assuming that 6 + 2 nm means 6.2? Or?
Harvey
Harvey
Harvey
Harvey
So, first torque to 4 ft/lbs, then to 6 ft/lbs
Easy come easy go, my moment of glee
... maybe I'm looking in the wrong place ... Page 10-09?
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
Interesting , the default spec for a 6mm bolt in Nm was 6 plus 2 for early cars , 6 plus 2 for 80-84 BUT the 85 >89 tech spec book (as Heinrich so gleefully pointed out
) reads 8 plus 2 nm and 90 > is 8 plus 2 nm ........ to convert to Ft lbs multiply by .75 (close enough) . It probably makes sense , especially for older 928s , to use new bolts when you are going to properly torque them with a torque wrench because you never know how "experienced " they are .
