How can I improve my ride on my ‘83 and ‘82
both my 928s ride a little rough over bumps. Is this normal or am I due to replace the shocks, struts and/or bushings? The ‘82 is all original and I believe they are the originals since the car’s mileage is approx 26k. the ‘83 is worse on bumps and is at 56k miles. Can anyone suggest what I can do or look for?
Replace it all. The rubber changes properties over time and doesn't dampen the way it was intended.
Same goes for the shocks, seals dry out and gas leaks etc. Only issue with those is that the rears have spotty availability.
A specialist replaced all my suspension rubber and shocks last year, it transformed the handling and feels so planted. But these cars don’t glide over bumps they just feel solid. Old tires that have gone hard will also add to the poor ride.
If the 83 has M474 Sport suspension (Bilstein shocks, harder springs), thats the way it should behave - over anything but perfect surfaces. Most of my 'ordinary' passengers remark on the hard ride on suburban roads. At speed, its a magic carpet.
Other than that, agree with above advice.
jp 83 Euro S AT 57k
jp 83 Euro S AT 57k
9two8 (09-24-2023)
See if you can find Bilsteins for your fitment. They work great.
Tires:
A good quality GT focused tire will help. Stay away from UHP tires, most tires shops will see "Porsche" and $$$ and push you towards UHP tires where margins are higher than an all season GT passenger car tires.
Bushings:
Replace all the bushings, UCA, LCA, Rack and check the sway bars. When bushings are bad it allows for lash and undamped movements that create very harsh feedback
Shocks:
The black / gray Boge shocks offer good damping and ride. Bilsten shocks are orientated towards performance and will add some edginess to the ride. I would change shocks last unless they are leaking or not working. I've noticed on other cars that Blsteins can sometimes fail stiff while other shocks fail loose so its worth checking them.
Ride height:
Make sure the ride heght is correct, most 928's are set too low n the front and this can create some slight crashing over road imperfections
This thread has some more detaled info.
https://rennlist.com/forums/928-foru...uspension.html
Bushings:
Shocks:
Ride height:
Former Sponsor
Hold on....
Low mileage cars require a different approach than high mileage cars.
Start with tires.
What is the manufacturing date on the tires on the cars? Sidewalls turn to stone after about 5 years.
If your primary goal is ride, buy a set of Pirelli P7's. Very soft sidewalls makes for very soft ride....I call them "Jello" tires.
Front shocks on these early cars is a snake's nest....venomous snakes.
Early model front shocks are like finding the Holy Grail. And the later model shocks are made for a different suspension design. You'll need an assortment of different parts to make them work, including new springs (for sure), on the '82.
I've resorted to dyno testing old shocks and dealing with this mess, only if the are bad.
As mentioned, the '83 might have a more aggressive suspension. More information required
Start with tires.
Tires:
Bushings:
Shocks:
Ride height:
Bushings:
Shocks:
Ride height:
any idea if this is an afternoon job, weekend job or winter job? This is my first time working on my 928. Both cars have been to my mechanic for timing belt, gas tank, clutch and gear shift ‘linkage’. Mr Merlin said I need to learn to do it all myself so im gonna jump in and replace the bushings.
should i do all the bushings, check the ride and then decide if i need to replace the shocks or replace the shocks at the same time?
I appreciate any tips on what NOT to do and what to look out for.
Hold on....
Start with tires.
Start with tires.
I know the ‘82 sat for at least 5 years before i bought it and it was from the original owner that only put 24k miles on it as he had tons of other cars.
The ‘83 has more miles (55k) and tons of maintenance records from 2006 but, no mention of suspension maintenance.
So im assuming they both have all original suspension.
I haven’t bought new tires for either since I bought them in 2021. So, I’ll try new tires and see how the ride changes.
Thanks for the advice and direction, Greg.
Thanks for this. I’ll start looking for the parts needed.
If you replaced _everything_
Two long weekends on a lift and with a GOOD press at arms length to use too.
Former Sponsor
I like this approach to take first. I’ll check the tire dates and see if new tires are needed and can do the trick.
Former Sponsor
There's also a whole song and dance on installing the lower arms and tightening them, which very few people understand and thus end up ruining the rear front lower rubber. This will result in the car sitting like an "off road" race truck for thousands of miles and requiring multiple alignments, as it very slowly settles.
