CLUNK Clunk clunk noise.. help
#32
the noise only happens over a bump. There is a louder clunk and then a few quieter ones. Imagine a loose piece of metal vibrating against the bodywork, over a large bump it bangs on the side of the car and then a few more times until it settles again. … that’s how it sounds. On smooth road there is no clunking at all.
#33
I agree with Rob.
Grab the end of the exhaust with your hand and shake it up and down and left and right. Does it bang at all.
#35
#36
Does the "tapping brake while in D at low speed makes clunk" point to something? help narrow it down?
I just tried rotating the half shaft and its rock solid. Parked in D, back up on ramps.
#37
Good luck with the investigation.
#38
Team Owner
So the real question did you try to tighten the CV bolts and the axle nut?
#39
I almost laughed when I read this post. Too many of us here already know that when a problem arises after you just did something to the car it is clearly related to what you just did. DUH!
M. Requin (07-08-2023)
#40
Just to make sure we are on the same page here regarding testing the exhaust's clearance...
When you test the movement of the exhaust, you must put a LOT of force on it, like if you're doing bench-pressing, almost.
Take those exhaust tips and FORCE them to the front of the car and then back. Do the same upwards.
When I FORCED mine side-to-side, an S4, and I muscled it, only then did I get the clunk - I couldn't believe it when it finally happened.
I wasted a whole year on diagnosing it because I was essentially just poking at it.
If ithe noise started after the new exhaust was installed, more than likely that's your smoking gun.
#41
I'll try again, but the new exhaust hangs lower than the orignal and its quite clear of everything - and the noise was there before I did the exhaust.
#42
#43
If you are casting the net wide then i would also include checking the gearbox mounts and also rear tailgate latch/adjustment and tailgate bumper pads
