Spider Installation Question
If you use the sealant, plan on removing the legs 1 by 1 with a sledgehammer after it cures.
Most of us use the factory gaskets as they were good for 30+ years and they are inexpensive.
I personally install the center section of the spider on the throttle body "U" and then mount the legs.
It is significantly easier to do all the hoses under the intake and the throttle body clamps this way than trying to attach it all in 1 shot, put together.
For various reasons I've had to remove just the plenum on a few cars without removing the legs. The only real tricky part is the clamps on the TB, but a long skinny flat-head driver makes easy work of this.
The rubber couplers can be slid far enough on the legs to allow the plenum to be installed, secured, then pull the couplers onto the plenum and tighten those clamps.
oh, also, should I address anything else at this stage of the game?
The stock gaskets have a glue made into them, which is why they are so darn hard to remove and why they are completely different on the two sides of the gasket. Note that the "glue side" can vary from "gasket run" to "gasket run". Sometimes, when stock manifolds are removed, 3 gaskets on each side will be stuck to the heads and 1 gasket on each side will be stuck to the manifolds. Sometimes the opposite occurs....3 stuck to manifolds and 1 stuck to head, on each side.
if you put anything on them, the glue will be defeated and they can/will slip and split. (A very quick lesson, if you've ever tried any type of sealant on 951 gaskets.)
Just make sure the intake runners are flat, which is not a huge problem on the pre-1985 US models and the pre-1987 Euro models (aluminum runners), but a huge issue on the '85/'86 US models (magnesium runners.)
14 to 16 ftlbs. works best on the stock gaskets...no more!
Center plenum always installed first...leave the clamps on the boot from the throttle body to the center plenum slights loose (and accessible, once the runners are installed.)
This allows one to get to and hook up all the hoses under the center plenum.
Runners go on after this. Slide the 8 boots over the center plenum before tightening manifolds, to get the best runner centering (to the central plenum) possible.
Tighten the boot you left loose on the center plenum to throttle body after the runners are attached, runner clamps are snugged, and runners torqued. Tighten runner clamps last.
By doing things in this order, the runners will line up better to the center plenum and heads, allowing optimum airflow.
