Wierdo speedo problem
My speedometer has been strange lately. When I move from a dead stop it doesn't report anything until I get to 20-30 Mph. Even then it isn't very accurate, as I've past signs that report your speed and it seems to be a good 5-7 Mph too fast on the gauge. It's a 1985 928 with an automatic transmission. I'm thinking bad sensor on the transmission? Maybe bad contacts on the gauge cluster? I must have taken that cluster apart four times by now and each time I get more scared touching it because it may fall apart.
You can try cleaning the contacts for the sender in the spare tire well.
They are in a molex connector usually behind a cover if it is still there. Takes a few minutes and couldn't hurt anything.
Otherwise it could be the sender itself which isn't exactly cheap.
https://www.fvd.net/us-en/9116062090...nsmission.html
I swear the 911 sensor looks the same as the 928 and is cheaper. For reference the part # is 91160620901, same as the 928.
https://www.aasesales.com/products/noloc-b52-112-108706
https://eeuroparts.com/product/genui...LQbtKcgywOFRcc
Found someone who had a similar issue but probably not my problem. I'll check the connection first in the tire sections and clean them. Good chance I haven't done that yet. Otherwise I'll probably remove the sensor off the diff and clean that. From the photos I think the sensor just pulls off? Not sure how that is held on.
https://rennlist.com/forums/928-foru...se-sender.html
The connections are in the top right corner of the spare tire well. There is a large bundle of wires with molex connectors there.
The sensor itself is held onto the diff by 1 bolt IIRC. It is just a hall sensor so it rarely fails, but can.
It can get cooked from heat back there. The one on my 81 looks like a toasted marshmallow at this point lol. It also has issues causing it to make the gauges read 10 mph too high at 60+
Next time you pull the pod replace the gauge foil with the Lutz Boards upgrade. I'll never install another gauge foil into a 928 after discovering this option in a car I bought.
