A thread about what parts are the same across all 928’s
Hiya,
I figured I’d start a thread about what parts are the same across all 928’s. So that’s all years and models. I’ve seen a bunch of cars listed to part out and I’d love to be able to buy parts from an older or newer year with confidence. Please list the parts you know will fit / work on all models.
some questions to get us started;
- Interior light housings?
- hoses?
- switches and sensors?
- AC components?
- ashtray?
- window motors?
- locks?
- nuts, bolts, and screws
- hoses?
- AC components?
- ashtray?
- window motors?
- locks?
AA996 (10-24-2021)
Archive Gatekeeper
Here's a quick pass through PET:RMS
Oil pan pickup
Clutch pilot bearing
Air filter
Oil filter
Diverter valve
Engine crossmember lateral support brackets
Fuel filler neck grommet to body
Carbon canister (but not without modification to hoses for some years)
Passenger side transmission mount
Front lower control arm/tow eye bracket
Front spring upper mount to body
Steering column universal joint
Steering rack boots
Steering column shaft (for later years, only in markets without airbags_
Rear upper control arms
All rear suspension control arm bushings- upper, lower, weissach joints
Rear suspension shock lower pin
Rear shock upper ‘supporting rubber’
Rear shock upper mounting plate to body
Rear shock piston rod boot/cover
Rear shock rod foam ‘snubber’
Rear swaybar clamp mounting to body
Rear emergency brake mounting plate to hub carrier
Rear wheel bearings
Emergency brake cables and adjuster hardware
Shifter shaft gaiter underneath shift boot- 5-speed
5-speed brake pedal
Gas pedal
Engine compartment upper crossbar
Some chunks of the lower front frame rails and front LCA reinforcement pieces
Inner and outer A-pillar/lateral roof pieces
Windshield surround frame
Cowl cover
Front and rear roof reinforcement pieces
Hood
Lower hood latch catch
Hood hinges
Hood shocks
Rear hatch shocks
Rear hatch lock surround grommet
Door reinforcement bars
Door seals
Window ‘thrust wedges’
Inner and outer door handles
Outer door lock assembly
Door pull cable assembly
Door stays
Upper window channel weatherstrip
Lower inner window weatherstrip
Lower outer window weatherstrip
Window felt guides
Window guide bar
Rear quarter windows
Door glass
Rear hatch glass
Headlight pivot bar
Headlight pivot bar lateral assemblies
Headlight covers
Hood insulation pad
B-pillar sound insulation
Door sound insulation
Cargo tie-down brackets, rear
Accelerator scuff plate
A-pillar covers
Door wiring cable guide
Door upper inner cover trim
Outer sunroof panel and its gaskets
Inner sunroof lining
Sunroof transmission
HVAC blower motor
Heater hoses, send and return
Heater valve
Alternator hose
Alternator hose bracket on back of splash shield
Starter
Rear windshield wiper arm
Rear wiper motor and transmission
Wiper hose check valves
Coolant reservoir level sender
Windshield washer reservoir
Headlight washer pump
Glovebox light
Dome lights
Door pin switches
Oil pan pickup
Air filter
Oil filter
Diverter valve
Steering rack boots
Rear wheel bearings
5-speed brake pedal
Gas pedal
Cowl cover
Hood
Hood hinges
Hood shocks
Rear hatch shocks
Door seals
Door stays
Window felt guides
Window guide bar
Door glass
Rear hatch glass
Headlight pivot bar
Headlight covers
Hood insulation pad
A-pillar covers
HVAC blower motor
Heater valve
Alternator hose
Starter
Glovebox light
Dome lights
Door pin switches
Oil pan pickup
Air filter
Oil filter
Diverter valve
Steering rack boots
Rear wheel bearings
5-speed brake pedal
Gas pedal
Cowl cover
Hood
Hood hinges
Hood shocks
Rear hatch shocks
Door seals
Door stays
Window felt guides
Window guide bar
Door glass
Rear hatch glass
Headlight pivot bar
Headlight covers
Hood insulation pad
A-pillar covers
HVAC blower motor
Heater valve
Alternator hose
Starter
Glovebox light
Dome lights
Door pin switches
Oil pan pickup
Air filter
Oil filter
Diverter valve
Steering rack boots
Rear wheel bearings
5-speed brake pedal
Gas pedal
Cowl cover
Hood
Hood hinges
Hood shocks
Rear hatch shocks
Door seals
Door stays
Window felt guides
Window guide bar
Door glass
Rear hatch glass
Headlight pivot bar
Headlight covers
Hood insulation pad
A-pillar covers
HVAC blower motor
Heater valve
Alternator hose
Starter
Glovebox light
Dome lights
Door pin switches
Archive Gatekeeper
Yes, any ashtray will fit any year, although the texture of the ashtray door varies between early and late (not sure where the boundary is).
Archive Gatekeeper
There you go, learn something every day!
Wow!! That's a helluva list...! I've got a saying that goes like this... "All 928s are the same... except THAT year..." Insert any year and you'll be pretty accurate.
Oil pan pickup
Air filter
Oil filter
Diverter valve
Steering rack boots
Rear wheel bearings
5-speed brake pedal
Gas pedal
Cowl cover
Hood
Hood hinges
Hood shocks
Rear hatch shocks
Door seals
Door stays
Window felt guides
Window guide bar
Door glass
Rear hatch glass
Headlight pivot bar
Headlight covers
Hood insulation pad
A-pillar covers
HVAC blower motor
Heater valve
Alternator hose
Starter
Glovebox light
Dome lights
Door pin switches
Oil pan pickup
Air filter
Oil filter
Diverter valve
Steering rack boots
Rear wheel bearings
5-speed brake pedal
Gas pedal
Cowl cover
Hood
Hood hinges
Hood shocks
Rear hatch shocks
Door seals
Door stays
Window felt guides
Window guide bar
Door glass
Rear hatch glass
Headlight pivot bar
Headlight covers
Hood insulation pad
A-pillar covers
HVAC blower motor
Heater valve
Alternator hose
Starter
Glovebox light
Dome lights
Door pin switches
what about the trunk latch? As in the piece that’s bolted into the hatch that lifts up?
Administrator - "Tyson"
Lug Nuts
Archive Gatekeeper
Valve stem caps too!
I'd think the rear hatch lock is the same 78-95, at least the non-alarm version. Nevermind that they all need to be keyed to the car. But given that a new one from Porsche is $500+, re-tumblering a lock seems worth the hassle.
Hiya,
what about the wiring harness?
Archive Gatekeeper
I'll go out on a limb and guess that there is only one wiring harness that is the same for '78-95- 928 612 011 00.
Gary Knox (11-26-2021)
