Powerless GT, Hall Sensor? or not? What else?
Received 1,679 Likes
Folks, in the continuing quest for the answer to why my '89GT cannot out-drag a late-model Camery I've narrowed the possible culprits down to a few components one of which is the Hall sensor. It has been suggested by Mr. Speake and others that the Hall sensor is a likely cause of lack of top-end.
The LH Service Training manual indicates that if the Hall sensor is toast that the timing will be retarted by 6 degrees.
I have checked the timing with a timing light. It's around 12-14 BTDC at idle and rises to 30-35 with rising RPM. This of course calls into question whether or not the hall sensor is bad.
What should the advance be? WSM says 10+/-2 at idle and 32+/-4 at 3k rpm.
(And - before someone asks - no - I haven't 'scoped the output of the sensor as my scope died last week and the "new" one from e-bay has yet to arrive.)
For context,
- the caps, rotors, coils, and wires are new.
- The throttle switch is working as it is supposed to.
- The injectors are clean.
- I have good fuel pressure at all RPMs.
- New fuel filter.
- Both pumps are recent vinatge.
- The final stage ignition modules were swapped with the ones from my '91.
- Grounds at the engine and battery are new.
- I cleaned up the grounds at the ignition stages.
- I've had a new MAS in there before with no effect.
- LH computer is new.
- Plugs are new.
- I also ran a test pipe in place of the cats for a while with no effect either.
- Temp II sensor resistance correct at the pins and ECU harnesses.
Oh, and the car passed a stationary emissions test with good numbers (with cats of course.)
No dog food in the intake. Etc.
What's left?
Injectors not firing due to harness issues? What's the easiest way to see if all my injectors are firing correctly?
Thanks in advance for any suggestions.
For context,
- New fuel filter.
- Plugs are new.
What's left?
If there were problems with injectors not firing properly, then almost certainly the ignition protection realy would operate and the car will run on 4 cylinders.
As you haven't observed this, then one or both of the knock sensors, or the Hall sensor is the most likely problem.
You will need to buy one of my diagnostic testers ! Coming soon !
Isn't the Hall sensor used to disambiguate the reference mark on the speed sensor? i.e. power stroke versus exhaust stroke?
In any case - I have a new Hall sensor and nothing but time on this Easter weekend. However, I don't see a way to get the hall sensor out and the new one in without removing the passenger cam cover to get access to the lower allen bolt.
This is not a problem (BTDT) - but - is there an easier way for someone with short fat fingers?
Throttle opens fully. Cable's fine.
Spark plugs are on the list of tea leaves to read...
Thanks Bern.
Thanks Bern.
Damn... no luck with the grounds?
Harness doesn't sound convincing since the problem would occur throughout the rpm range, not just in the midrange as you have described.
MAS wiring? how does it run unplugged?
Something to do with removal of intake? When did problem commence?
Yes, u/s one injector or spark plug can be enough to trigger the system - had this on a car this weekend.
If the Hall sensor or its connections are bad, the EZK ECU can't differentiate which knock sensor outputs a signal. So to be safe, a faulty Hall signal kicks the ignition timig back 6 degrees
Good luck !
Good luck !
Rest in Peace
Dave;
I had a Hall sensor issue once on an 88 5 spd. Car would cut out under high load, progressively to the point that it would only travel under part throttle. Eventually the car wasn't able to start.
Seems as though, in my frugal nature, I reused the existing smog pump belt (that was too long) at the time of a T-belt/h20 change. When I correctly tightened the smog belt it (being the pump body) 'pinched' the wire to the hall effect sensor thus causing all my grief.
I wasted about a month tracing it down and eventually a P-car dealer took 16 hrs to find the problem. That, a new belt and ~5" of electrical tape fixed the issue.
Check for wire continuity...
Scott
93 GTS
89 GT
Scott
93 GTS
89 GT
Originally posted by Old & New
When did problem commence? [/B]
i.e. it was a known issue when I bought it.
Re: Powerless GT, Hall Sensor? or not? What else?
Originally posted by worf928
What's left?
What's left?
That is the kind of info I was looking for - other effects of hall sensor failure.
... correctly tightened the smog belt it (being the pump body) 'pinched' the wire to the hall effect sensor thus causing all my grief.
... a P-car dealer took 16 hrs to find the problem. That, a new belt and ~5" of electrical tape fixed the issue.
I trust Jessie never saw that bill?
Thanks Doc.
Yes, u/s one injector or spark plug can be enough to trigger the system -had this on a car this weekend.
But, if the hall sensor is bad - which means the EZK doesn't know which knock sensor is ringing and it doesn't know if the crank is at TDC on the power stroke or the exhaust stroke - why the H&!! does the lump even start much less run?
Good luck!
Hmm... maybe I can put off the tax returns until next weekend... let's see... 4/17. Nope.
Originally posted by ErnestSw
I don't see anywhere that you've checked the flappy valve.
Is it working?
Re: Re: Powerless GT, Hall Sensor? or not? What else?
Originally posted by SharkSkin
Have you run a compression check? If so, what were the numbers?
As in - no. I have not done a compression or leakdown test.
However, if the hall sensor is not the problem then looking at deeper problems will be the next task.
D.-
I know tax time is here again, but maybe afterward you can take a ride down & we can stare at your engine compartment with beer-addled minds and see if we can brainstorm something.
I have a few uncorrupted brain cells left to contribute to the cause...
