K&N air filter
K&N air filter
Putting in my O/Hed MAF and my car has a K&N filter, so is it just mine or are they a poor fit, it looks to be about 1/2 inch to long to fit in. Do they swell with time? Or did different year air cleaners come in different lengths?
Dan
87 S4
Dan
87 S4
Keep in mind that the 928 air filter is also used in the Bugatti Veyron (x2)...
The following 2 users liked this post by 928 GT R:
gazfish (07-21-2021),
Zirconocene (07-21-2021)
I think that you're going to get a lot of recommendations to go back to stock. Given how the MAF works, with the burnoff cycle after the engine has been turned off, the K&N filter will work against that by continuing to provide oil/vapors that will contaminate the filament.
As to answering your question, I don't think that there are different lengths of air filters. I don't know if they swell with time, but I removed the K&N filter that was in my car and didn't observe an issue with fitment.
Cheers
Cheers
928 GT R (07-21-2021)
NOTE the above information about the oil laden air contaminating the MAF wire not withstanding.
Please consider, the KnN advertising team did a great job, that to whomever put that part into your intake system.
If you look carefully you will find a fine layer of micro particles that have come past the part and is laying/sticking on the lower air cleaner housing.
get a white T shirt and wrap it around your finger then wipe the housing, you will see this for yourself.
NOTE This same air has also gone into your cylinders and has been wearing out the cylinders, rings and pistons.
The factory filter flows great and catches 6 times as much grit as the dirty KnN does.
NOTE The hump points to the sky on the factory filter.
I found that the OE filter has a better seal on the 928 than a K&N. Over-oiling is the issue with K&N filters.
We have ran them in our Mercedes, Porsche 944s, and our GM trucks in the family with great success. I am very conservative when re-oiling after a thorough cleaning. Been doing it for 2 decades now with no issues
However, based on my experience with a K&N and a 928, I prefer the Mann, or genuine Porsche air filters.
I went to Pelican and have ordered one even before I posted my question. I do have it on as I am trying to get it cranked today, will switch out filters when the other arrives. In the XJS -V12 world there was a lot of discussion about K&N and everyone agreed there was no real advantage to them.
Dan
Dan
The K&N in my 81 fits fine. No MAF in that car but I also have them in all my other cars. My UOA reports come back with lower silicon levels than most others I see on the various forums and in using then for close to a million miles in 9 different cars I've never replaced a MAF..
WALTSTAR (06-28-2022)
Pete do a white glove test,
lets see what you find.
virtually every 928 with a KnN that I see,
has the same gritty film lining the air cleaner base.
the 928s with factory filters are clean or might have a oil film but not the grit
People pay big money for intske porting, polishing, and cylinder honing - this just does it while you drive
928 GT R (07-23-2021)
Every car that Ive worked on with a friend over the years with a 'tuner' air filter, always had a dusty intake system.
More air without more surface area = more dirt.
Speedtoys (07-22-2021)
This video was enough for me to throw out my k&n filter in my Durango in favor of a paper one again.
https://www.youtube.com/watch?v=sJ3L-E-ufYo
K&N is the kind of product for people that could never read a clock with hands in school.
beran earms (07-22-2021)
The thing I don't like about the K&N is how porous it is. If you shine a light on the background and eyeball it you see how porous it is. The principle is to use oil to trap dirt instead of inhaling it into the engine. There is no free lunch here. The only way to get more air is having a bigger filtration area. The paper elements achieve that by giving you more surface area as a result of more pleats that let more air passes through.
The following 4 users liked this post by HenryPcar:
Air filter, oil filter, air intake filter?
im looking to replace the cylindrical one at the front of the engine but the markings have worn off so I can’t tell the size and wanted an opinion as to the brand and size. I’d prefer to stick with a dry filter as opposed to an oiled one. I bought a Mann filter. I also noticed the elbow that connects to the bottom of the air filter box at front was busted off so I don’t think it was going much of anything. I fitted it back in but am assuming it’s not airtight. What effect does that have on the car? I was thinking of taking a field trip to the plumbing section of a hardware store to find an elbow that’s a similar size and then Plumber gluing it on to replace the broken one. Thoughts?
