928 Forum 1978-1995
Sponsored by: 928 Specialists
1980 928 clutch return
Old Jun 25, 2021 | 12:28 PM
Larry 928's Avatar
Larry 928
Cruisin'
Question 1980 928 clutch return
Hi, in process of reviving my neglected garaged 928s. The clutch depress but does not return freely. ?? Fluid, slave, ?? Ideas ! Thanks, Larry
Old Jun 25, 2021 | 03:29 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
if you have questions like this i would suggest that you revive the whole clutch system
pilot brg
TOB,
guide tube,
discs,
PP,
release arm bushing,
master cylinder modded to an 75mm length with a reduced length coil spring.
new blue hose,
new slave,
new Greg Brown flex line from the swaybar mount to the slave,
replaces the flex and short hard line over the starter .
while your at it get a new master cylinder and brake booster swap those in as well.
Old Jun 25, 2021 | 04:05 PM
Larry 928's Avatar
Larry 928
Cruisin'
pilot brg
TOB,
guide tube,
discs,
PP,
new blue hose,
new slave,
Thanks, Greg Brown. I read last night thru the many comments on the “Barn Find” clutch saga. Whew !
Old Jun 25, 2021 | 04:12 PM
Larry 928's Avatar
Larry 928
Cruisin'
Thanks Mrmerlin for the comments regarding the GB hose ! I assumed a complete clutch review is necessary and thought a return spring might be the problem as I had on a car any years ago. , Larry
Old Jun 25, 2021 | 04:58 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
NOTE replacing one part guarantees others will soon fail then you can revisit this issue again soon.
my suggestion is to fix it once and move on.
Old Jun 26, 2021 | 09:14 AM
Petza914's Avatar
Petza914
pilot brg
TOB,
guide tube,
discs,
PP,
new blue hose,
new slave,
Don't gloss over the highlighted item in Stan's response
Old Jun 26, 2021 | 02:12 PM
PorKen's Avatar
PorKen
Inventor
It sounds counterintuitive but when there is air in the clutch hydraulic system the pressure plate cannot push the pedal back into position (cannot overcome the assist spring).
Old Aug 3, 2021 | 10:37 PM
Larry 928's Avatar
Larry 928
Cruisin'
Default ‘80 928 clutch.
Raised and reverse gear engages, forward(2nd) engages sporadically then coasts to stop even though engine at 1500 rpm. Stopped as didn’t want to overheat the clutch. Mice had feasted in my sunflower seed and shared space in the engine compartment. I’m humiliated but ask for advice with this status
Old Jul 17, 2024 | 01:37 PM
LEBARK's Avatar
LEBARK
6th Gear
HI Marlin
What is "TOB" and
What is PP
Regards
Old Jul 17, 2024 | 01:45 PM
Kevin in Atlanta's Avatar
Kevin in Atlanta
Throw out bearing.
Pressure plate.
Old Jul 17, 2024 | 02:25 PM
LEBARK's Avatar
LEBARK
6th Gear
Hi Mr Merlin
What is "TOB" ?
and "PP" ?
Regards
Old Jul 18, 2024 | 12:15 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
Kevin answered it correctly in post 10
Old Jul 27, 2024 | 02:20 PM
Fugi's Avatar
Fugi
Would anyone recommend going to a single clutch vs. replacing the dual clutch?
Old Jul 27, 2024 | 02:59 PM
Kiln_Red's Avatar
Kiln_Red
I don't know what others might suggest, but I personally prefer the earlier clutch. I'm not sure why anyone would switch from one system to the other, as they're both robust and adequate for their respective applications.
Old Jul 27, 2024 | 03:13 PM
Fugi's Avatar
Fugi
Thanks for your prompt reply. Who do you think is the resident dual clutch installation and troubleshooting professional in the US?
