928 Forum 1978-1995
Sponsored by: 928 Specialists
Automatic transmission not engage
Old 08-21-2021, 07:49 AM
  #376
FredR
FredR's Avatar
Originally Posted by Fabien92
And my transmission never failed until a « friend » drove my 928 and broke it ... 🤬 F@&cking ex friend 🤬
Has that been established as a fact or is that frustrated humour?
Old 08-22-2021, 06:07 PM
  #377
Fabien92
Fabien92's Avatar
Both !!!
Our analysis:
1 - (Big) Shock on the pan with hot ATF. This shock was not here when we changed ATF some weeks before.
2 - Dust / debris in free hot AFT flow
3 - When cold, dust and debris stuck in the valve body
Old 08-22-2021, 11:33 PM
  #378
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Both !!!
Our analysis:
What?
Shock on the pan, hot fluid, dust???
People dont break these auto transmissions..they just dont. YEARS of negligence adds up one day, and it will suffer..but...
Old 08-23-2021, 01:52 AM
  #379
Fabien92
Fabien92's Avatar
No negligence for me and previous owners. Just a bad friend who drove my car ...
Old 08-23-2021, 01:54 AM
  #380
Speedtoys
Speedtoys's Avatar
That doesnt make sense. A 'driver' isnt going to break these transmissions.
When you break it..with over 1000Hp, then you can say "it just broke".
Old 08-23-2021, 02:14 AM
  #381
Fabien92
Fabien92's Avatar
Old 08-23-2021, 02:23 AM
  #382
Speedtoys
Speedtoys's Avatar
What did the dent do? Leak all of the fluid? Just trying to understand the root cause...thank you.
Old 08-23-2021, 06:38 AM
  #383
FredR
FredR's Avatar
Both !!!
Our analysis:
Fabian,
I have suspected the dink in the pan as being relevant ever since you introduced it but the notion that it caused debris to enter the system would trouble me some.
I would think it is quite possible that some debris collects in the bottom of the pan and maybe that was disturbed by the "event" but how would such get past the filter unless the filter element was somehow distorted in the process and one presumes you would have spotted such?
As I understand the oil sits in the sump and is sucked into the filter that is normally flooded- presumably why it has a large footprint- and nothing should get past that element. For sure once that system is compromised and crap were to get in there, it would not take much to cause the problem you experienced. There is a lot to be said for ensuring one knows the real cause of such an event if for no other reason to learn from it.
That being said it takes quite some effort to dink the tranny pan [given the way it is somewhat recessed] or so I would think and if one did I am pretty sure one would know all about it. I have never read of such happening previously but as with most things in life there is always a first time!
Fabien92 (08-23-2021)
Old 08-23-2021, 06:18 PM
  #384
Fabien92
Fabien92's Avatar
Bonjour Fred,
It was also the first time that a transmission was fully down !! I will never be sure about the root cause of my failure. I just try to understand a scenario
BTW, we will check and plug the vacuum line on next saturday. I hope it's the end !!
Schocki (08-24-2021)
Old 08-27-2021, 09:38 PM
  #385
Fabien92
Fabien92's Avatar
Well done ! 😃
The vacuum line was disconnected after the steel hose.
All upshifts change smoothly right now 😃👌
Now more slipping, just between 2400 and 2500 RPM. I will adujst it when I will receive my new modulation valve.
Today I am a new happy 928 driver 😊
The following 2 users liked this post by Fabien92:
Schocki (08-28-2021), Speedtoys (08-30-2021)
Old 08-28-2021, 02:41 PM
  #386
Schocki
Schocki's Avatar
The car should shift like never before now. Especially when warm it should be very smooth.
Keeping my fingers crossed that a new modulator valve will do the trick.
Good to hear that I was not that far off with my vacuum line disconnect.
Fabien92 (08-28-2021)
Old 08-28-2021, 07:47 PM
  #387
Fabien92
Fabien92's Avatar
It’s a new 928 😊👌
I have a new transmission rebuild at 98% right now 😊 I hope to be soon at 100% with the new modulation valve.
The first 100 km since 8 months are very good 😊 So happy !!
Gary Knox (08-28-2021), Speedtoys (08-30-2021)
Old 08-29-2021, 01:45 AM
  #388
FredR
FredR's Avatar
Was the trailer there "just in case"?
Fabien92 (08-29-2021)
Old 08-29-2021, 10:53 PM
  #389
Fabien92
Fabien92's Avatar
One last question
About B2 piston, I don't know if my B2 brake band clearance is good. Is it possible to try a longer pin without to remove the pan and to measure the B2 brake band clearance ?
Ie. If I have the pin of 48.0 mm, can I try the next pin of 48.8 mm ? All sizes are 47.2 mm, 48.0 mm, 48.8 mm, 49.6 mm.
Old 08-30-2021, 03:25 AM
  #390
Schocki
Schocki's Avatar
It should be possible but I'll leave the answer to our tranny expert GB.
I don't think, that a longer pin will do the trick. AFAIK B2 is activated in all forward gears, if B2 fails you can only drive backwards.
Fabien92 (08-30-2021)
Quick Reply: Automatic transmission not engage
