The Sand Shark - 83 Euro S
Sorry Petza, "worthwhile " ? if no big shipping costs involved , i think this is as "for free" !
yep looks like a fit. Will be nice to have a part someone can vouch for.
I think you should also consider going full EFI. I'm perfectly willing to sell you a perfect K-jet but the stage your at with the engine in pieces and virtually a clean slate it's the ideal time to make this into a modern car. An aftermarket ECU with modern coil packs and fuel injectors transforms this engine. It will make it simpler too. It's amazing the amount of crap on top of that engine there to make the K-jet work reasonably well. It will enable you to get rid of the distributor and the dreaded Green wire too. Other stuff to consider is also the crankcase breather system. I would suggest some research into the various aftermarket systems kits available. I have shifted my remote oil filler and removed any possibility of sending any crankcase gas down the intake and dilating the 98 fuel. Take your time and do plenty of research.
Basically it just converts the 928 into a modern engine.
Mostly drivability. There will be a slight power increase at WOT but the most improvement is right where the car spends most of the time in normal driving. Most of this is down to getting rid of a distributor and having a timing map that covers the whole range. The car is more lively with an instant response. The K-jet is a reactive system, you stab the throttle and a few things happen and eventually, the system dumps a heap of fuel down the intake. The distributor flings some weights out against a spring and you get some timing advance. If your car is an Australian delivered car you will have the different vacuum advance to a Euro.
Surprised to see the toolbox complete, that spare is nuts too weights a tonne. Would that tyre inflator have come with the car?
It's handy to have the tow ring in the kit. That means you have the right one with the correct thread. Have you worked out whether this is an Australian delivered car yet or a Euro. They came with a tyre inflator but I'm not sure whether that's original. Carpet is the same colour as mine. I would keep those wheels too. Design 90's are the ultimate but those are second best.
I’m fairly certain it’s aus delivered now. Very little documentation came with it but there’s a gold sticker inside the fuel flap specifying to ‘use only super unleaded 95 in Australia’.
My neighbour’s uncle works for Porsche so I’ll see if I can squeeze him for a Certificate of authenticity.
On another note. My partner surprised me with these this morning... lucky boy!
Shawn Stanford (09-22-2020)
Bit of progress tonight, pulled the fuel tank for cleaning. The amount of crud built up under there was nuts. She’s living up to her name. Any tips for cleaning? Was going to pressure wash and if that failed see if my partners hand fits through the fuel level sender hole.... How’s the pile of roach turd 😳
Not doing the fuel lines on these really is a death sentence. Literally crumbling to the touch.
Shawn Stanford (09-23-2020)
yikes! Good catch on those.
