'82 Fuel injector replacement options...
Just make sure you use something in the range of 21-24 lb/hr or their cc equivalents. Any less and it will run lean, any more and it will run rich. The NB 02 sensor can only account for so much.
This topic has been the subject of much debate. I suggest you do thorough research before changing to any nonstock configuration. Listen to our experts carefully. I went through the same thought process with my US ‘83 - the idea of using the GB adaptors with 4-hole modern (and cheap, but high impedance) injectors does seem alluring - but read the following thread carefully. It didn’t take much research for me to decide to stick with stock. You can search and find a number of other threads too. And btw, the GB adaptors were not intended for your application, as noted by GB in this thread.
https://rennlist.com/forums/928-foru...dance-car.html
Also, I posted my Witchunter results at post 29 in the following thread. If it were me, I’d spring for new (correct) injectors, they are still available. Pricey perhaps, but still available. Or source good used ones. You may not need to replace all 8, correct? How much variance do you have? If you just need to replace one or two this is a no-brainer.
https://rennlist.com/forums/928-foru...oses-83-a.html
Be sure to replace all rubber seals and all flexible underhood fuel hoses if that’s never been done - also documented above. Use DC 111 Molykote on all the rubber seals and use anti-seize on the fuel line junctions, only the threads, and torque only to recommended settings so that they can all come apart manageably next time. Re-use the hats on the injector-to-fuel rail tubes. Roger sells a great kit containing all the injector seals and connecting tubes, and stocks all needed fuel lines.
Good luck!
Rick
I'm glad you mentioned that -- I had forgotten about that. I got all excited too when I read that on GB's website. I spent a LOT of time poring over every single bit of information I could find on topic, both on Rennlist and elsewhere. After doing the research, I asked Roger -- who stocks these adaptors -- about exactly which injector is recommended to go with them for a stock L-jet application. There isn't one, and I was advised to stick with stock. Of course, I encourage you, the OP, and anyone else to spend the time, do the reading, pick up the phone and do your OWN research.
Soapbox time: Having said that, this does bring up the perennial learning/teaching point: Just because you CAN make a "change" on your car, does that make it "better"? Just because somebody says X on the Internet, or parts are offered for sale, does that mean they will work as well as stock? What if there's even more evidence, and some people report that things "work" -- does that mean that they have put in the hundreds or thousands of hours of testing, across a large variety of cars and conditions, and put in anything even approaching the testing the factory did, to ensure that it "works"? It's one thing if we are talking about a gasket or a fuel line, but an entirely different thing when we are talking about the heart of the fueling system. What are the potential consequences of getting that wrong? Are you willing to roll those dice? Are you willing to roll those dice and make that armchair quarterback recommendation to someone else who has to run those risks? What if THEY destroy their L-jet controller or even blow up their engine following your advice?
The only reasonable approach to take here, as in virtually every case about aftermarket or nonstock parts, is to come in with a very strong presumption that the factory parts are best unless proven otherwise by clear and convincing evidence. Sometimes that standard can be met. In this case, that standard is not even close to being met -- in fact there is very little evidence at all in favor, and much expert advice against. It's up to each individual owner to take the time and effort to do their own research and come to their own conclusions. Some people will WANT to experiment and be a guinea pig, and that's perfectly fine as long as it is an informed decision (and not fine if they think it's perfectly safe and not an experiment). But frankly, without this presumptive approach, it's all too easy to mess up our exotic cars -- remember, these were some of the most expensive cars on the market in their day, and the top of the Porsche line -- because of the law of unintended consequences.
End of soapbox.
I don't think you have said anything that I can't agree with. I see your perspective and don't discourage anyone from making their own informed opinion with regard to part options. Just because there are options doesn't mean that an improvement is available over original equipment. That said, I see GB's upgrade as a no-brainer. It's economical, increases serviceability, and works. Are you concerned about low impedance drivers versus high impedance injectors?
High impedance injectors are originally intended with 'saturation' drivers, or a single current signal. The injector itself is a critical component for this type of signal, as the 12V power signal is constant. The lower current circuitry is achieved via the increased injector coil's resistance. In other words, driver current is dependent on the injector in this application. High and low impedance is really pretty generic language. Using 12 ohm (high impedance) injectors versus 16 ohm (high impedance) injectors means more current on its driver. How do we determine this is okay?
A high impedance injector driven by an L-jet controller will open in the same manner it was intended, then be switched to stay open at 'hold' current that isn't needed with this injector type. It's this side of the L-jet command that should be our point of interest in determining retrofit injector compatibility. Will the injector stay open for the whole pulse width? The 'hold' current will be between 200-250mA, depending on the 'high impedance' injector chosen. The driver current on a Euro S2 is a 'saturated' 750-830mA for comparison. The L-jet 'hold' current can easily be simulated, and a proper bench test with a 947 blue top injector can be executed.
The Lucas - D1540BA injector would be the most ideal replacement for MY80-84 US cars with the GB adapters IMO. These are peak and hold injectors with the same plug and body as the 947 injector from all that I can tell. The caveat is that these aren't 4-hole injectors, though they're a lot easier to find than 0280150154 injectors.
Chuck
Chuck
I’m sure others with much more knowledge will chime in, but it’s good you appear to have injector pulses on 7 and 8. Have you confirmed whether you have spark on those two cylinders? And what do those two plugs look like compared to the others? Have you tried confirming visual
spark?
Btw the L-jet system grounds out pairs of injectors via a common pin, but 7 and 8 are not grounded together, so FWIW that probably means not a controller type of issue (good news). More here post 3: https://rennlist.com/forums/928-foru...tml#post285204
Besides spark, another potential issue is the individual connectors on 7 and 8, is it possible that wires are cut or frayed? Also the little pin fingers (on the harness side) can sometimes be bent or distorted and not make proper contact. Corrosion on the pins is also a constant issue, have you made sure all injector and harness pins are nice and clean? How about the big connector at the Ljet controller, the connector at the central board that supplies power (on my ‘83 it’s connector X), and the two grounds on the passenger cam tower? Frankly a power/ground issue wouldn’t seem to fit your symptoms, but while you’re in there, you should tidy everything up. Get some deoxit and use liberally, and you can find threads sharing advice on cleaning brass connectors etc. Thinking out loud here...
As for the injectors themselves, you say they’re only ok. How much variance did you have and did you track which injectors you installed in which cylinder? What were the numbers on 7 and 8? Did the injector cleaning service do a pulsed flow test, which would presumably confirm the injectors were actually operational? Bottom line, if you suspect injectors on 7 and 8, that should have been apparent in the test data. If 7 and 8 tested similarly to all the others (and presumably they did or you wouldn’t have gone to the bother of putting them in), then the problem must lie elsewhere. I recall one thread from years ago where someone traced rough running to something jamming one of the valves open, so just approach this with systematic testing and see where it leads you rather than throwing parts at it.
Edit: One more random thought, I wonder if vacuum leak(s) on those two cylinders could cause these symptoms. Did you put in new rubber seals on the injectors AND did the injectors seat properly? (Pedantic addition, be sure to coat those seals with Molykote DC-111). Sometimes the fuel rail with all injectors attached makes it hard to get all injectors to seat properly and simultaneously. There are other potential sources of leaks. I don’t think we know the history on the car, was it running well in the past and something changed? If all else fails consider doing a smoke test, but start with checking spark, and inspecting plugs.
Hope this helps. Good luck!
1.. definitely getting good spark to all cylinders ,even 7 and 8. Those plugs were actually damp when pulled them this morning,clean but I would say running rich which is interesting since as I said,I can unplug the injectors and it doesnt affect the running of the engine.
2.. All the injector connectors are new, most were broken when I got the car. I bought new Bosch connectors and soldered and wrapped them properly. Noid light shows a good signal to all 8.
3.. I did not check the " big connector" on the CE panel.
4.. rechecked cam cover grounds..they were clean but I cleaned them again.
5.. Injectors..... I dont think they were installed in the same way they came out...same side,yes but not same cylinder I,m sure. The report from Witchhunter on these 4 showed all flowing between 229-235 cc per minute and good spray pattern. Pulsed flow between 105.5 and 108. Seems ok and they did note that it took a week in the cleaner to get them from poor to good. The other 4 were about the same.
All received new rubber seals and hoses when I re-installed them, but its possible the back 2 are not seated properly.....I will have to check.
and as far as the history of the car...PO said it ran ok until it just died 1 night on the way home from work....but I am fairly sure thats not the real story. I bought it -non running( never owned a Porsche and thought this would be a fun way to learn about them. That decision definitely damages my claim that I,m not crazy, but Mom had me tested and they said I,m not! ).....it fired on starter fluid at his garage.
I brought it home and after doing some digging found both caps that plug the DE-Cel ports on the throttle body were gone. I plugged that major leak and the car fired. And since I have been plugging away at it as time permits. It has always had the cold starting issue and the rough idle and thats what I have been chasing. When its warm it will fire and sit and idle all day, drive it down the street and you can tell its down on power and not firing on all 8. I do have receipts back to 2010 for all work done on the car and that includes timing belt, Air flow sensor, plugs,wires, suspension work etc.... so it has had some love, but its also had a hard life. I think alot of 928s fell in to the same boat......decent solid cars that were just neglected or worked on by folks that had 0 mechanical ability.
Your flow numbers are good, pretty close to what mine were (I posted a pic in the other thread). And a wet plug means fuel (good) but not combustion (bad). And probably also rules out a vacuum leak as a problem, or at least if there is a leak it's not causing the lack of combustion.
Is it possible the spark plug wires for 7 and 8 are swapped? Are both plugs gapped OK? How's the cap look on those two cylinders?
Not sure what else I can suggest for you right now. Are you sure nothing fell into the injector hole when you had the injector out? Of course it's possible that something got in there a long time ago. But before we start talking boroscopy let's stick with the basics!
Please keep us updated and good luck!
