New Product: low-cost 2-piece harmonic balancer
Received 1,560 Likes
So, here it is:
Two-piece harmonic balancer. No more pesky having to turn the crank with a 27mm socket to check your timing belt. Just rotate the marked portion until it lines up with the pointer on the center belt cover.
It also makes dialing in your cam timing a snap!
It's very easy to convert your OE balancer into this new two-piece design: just wait long enough.
(Editor's Note from Captain Obvious: the above is sarcasm.)
I took this off of a 50k-mile '87 this morning.
Doc Brown's been singing the swan song of the original balancers for some time. This is a coda for that song.
Basic Site Sponsor
Basic Site Sponsor
If you buy the custom 2 piece balancer complete kit, does it come with a new set of main bearings?
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
https://rennlist.com/forums/928-forum/1161182-free-shipping.html#post16104050
Team Owner
just get some super glue and wipe the mating surfaces with alcohol,
and glue it together,
It will be almost good as new !
NOTE For your coffee table damper only.
It's in the old katalog...
Bottom of page 88 ...
Contact these guys for help with distribution, they are terrific and this is the perfect product for them:
In all seriousness, I'm going to start a new (serious) thread about this. I want to gather some thoughts on why this failed the way it did.
great ! do you ship to Belgium ?
I know that this new high-tech is expensive.
After updating to the new design, is it possible to do rebuilds by only ordering the rubber part, "when it wears out?" Or is it long life, never-wear-out rubber?
