Help - 1987 S4 - stripped bolt on camshaft bearing cap
I'm in the middle of tearing down the engine on my 1987 S4 due to a bad head gasket. I was going to remove the camshafts today, and of course managed to strip two bolt heads on the camshaft bearing caps.
I was able to carefully loosen 15 of the 16 bolts on each side, but unfortunately there was one stubborn bolt on each side that wouldn't crack loose. Sure enough, the triple square bit slipped a tiny amount and stripped the inside of each bolt head.
So what now? What is the easiest/surest/cleanest way of getting these last two bolts loose? Looking for some options before I do anything (else) stupid.
Thanks in advance,
Rich
Thanks in advance,
Rich
Carefully drill off the heads. Use a vice grips to remove what's left.
Basic Site Sponsor
Basic Site Sponsor
Thanks in advance,
Rich
Thanks in advance,
Rich
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
You can also try heating it with a propane torch. The heat will cause it to expand which may move the sealing surface just enough that when it cools back down you'll be able to remove it. After it cools down, you can also try cooling it further with ice which will make it further contract.
I recently tried all these methods but drilling the head out was surprisingly easy. The hammering, even in anger, didn’t work for me. I forget the size bit I used but it was such that it only took the head off by the time the tip of the bit was reaching the ‘core’ of the bolt. As others have said, the headless bolt, stud at this point, came off using only my fingers.
If you are going to drill it buy a left handed drill bit. Best case it bites and backs the bolt out, worse case you drill it out.
