View Poll Results: For only a head gasket replacement only on a 16v and no other service work, would you
Voters: 59. You may not vote on this poll
Blown/Damaged Head Gasket?
#76
Anyone have an old scrap square tooth timing belt they want to send me for the cost of postage. I want to cut it up. Looking to paint the non-running surfaces of my steel timing pulleys (cam, oil pump, crank, etc) and want to mask off the toothed portion with sections of an old belt during the process.
Also, anyone have scrap 3 bolt header flanges? I'm looking for 2 of them to make an adapter to go between the 85/86 round tube SS headers and my current stainless Y-Pipe and would prefer to not cut and weld either of those, unless someone actually has one of those adapter pieces around.
Thanks.
Thanks.
#77
Here we go.
Battery disconnected, hinge positions marked, and hood off. I'll work on disassembly and removal while the 4.7L is en route.
Sunex 8300 GB Engine stand is assembled (thanks for the recommendation in another thread Greg Brown), Harbor Freight Shop Hoist with pneumatic ram upgrade and balancer assembly is on hand to be put together. Waiting on some parts too.
#78
Pretty productive first few hours
- Crossbrace off
- Fuel lines disconnected at the intake legs and intske removed
- supercharger intertcooler deinstalled
- Radiator and most of the coolant drained
#80
Nice job so far.
Friendly tip - whenever you start to feel impatient while working on the car, put down the wrench and take a break.
#83
Let us know what you think about that 8300GB stand. Been looking at one and after yesterday messing with this latest rebuilt engine I want one with a crank.
#84
You can actually see it folded down under the boat trailer in the coolant draining photo.
I'll let you know how it works with the motor mounted as I'm going to remove and reseal the oil pan and install a stud kit, so I'll be cranking it upside down once on the stand.
#86
What's the consensus on whether I should upgrade to the Porken tensioner while I'm doing all of this on a 16v motor if I have a functioning regular tensioner?
#87
How difficult will it be to access your tensioner to retension after 1500 miles? How difficult is it to access your tensioner for anything with the extra apparatus you have installed at the front of your engine?
#88
Pulling the airbox is easy, but the supercharger, not so much.
With the Porken Tensioner, is it self-adjusting like a normal serpentine belt tensioner, so no break in or periodic adjustments, whereas the OEM one requires manual adjustment?
If so, there's my answer. Thanks and let me know.
#89
Quite difficult.
Somehow I thought you might lean that way if you needed to remove the supercharger to access the tensioner.
#90
I am sending tensioners Pete, but I was going to say I would strongly recommend the Ken's tensioner in this case.
