Remote Control Suggestions?
Hi All
Is there a consensus out there on the best way to go on aftermarket remote controls for 928 door locks?
I was considering that upgrade on my 91' S4
Thanks!
Thanks!
You picked the right year for keyless entry. Easiest year (90+) to wire.
Any of them will be fine. I have a couple of no name versions scored from China.
I bought a 4 door setup off eBay when doing my build on my '79, which gave me 2 spare actuators for about $5 more than the 2 door kit.
Works perfectly.
Works perfectly.
This is the one I installed on my 89s4. Somewhat easy to install; Works perfectly!
https://www.bergvillfx.com/index.php...ry-system.html
Electron Wrangler
Lots of threads on this, search is your friend. You can do locks and hatch without too much trouble, many options for systems (changes over time - but few compatibility problems regardless on late models). In a '91 this gets you good integration with the interior lights.
Alan
Alan
