TB bearings/flappy bearings leaking effect?
Received 1,543 Likes
This small constant leak will not cause a hunting/surging/unsteady idle. It may result in a slight (~10 rpm) higher idle. But, something like that is going to be difficult to measure unless you do before and after measurements and change nothing else except the bearings.
The GT hunting idle problem I diagnosed was a fairly-new perfect-looking CPS that was providing a poor signal to the EZK. This poor signal caused the EZK to 'believe' that the engine speed was hunting through the idle timing map. The EZK was thus, changing spark advance based upon incorrect speed values, thus *causing* the idle to hunt between 600 and 900 rpms.
Isolating this fault took a Hammer, messing with idle timing with the SharkTuner on a second set of ECUs, and a timing light with an RPM display.
After I installed a new CPS the hunting disappeared and the idle was consistently 775 +/- ~12 rpm.
Interestingly enough, when I reconnected the tank vent system to the air guide, the idle rose to 800 +/-. So, there is something not quite right with the tank venting system on this GT. (It was disconnected and plugged because a faulty tank vent system can cause a fluctuating idle.)
But, the idle is still rock-steady (see below) even though it is a bit higher than I would like.
This is the second time in 20 years I've encountered this CPS failure mode.
should I have ROCK STEADY 775 idle on this 28 year old, or is a little float more the norm?
In the case of this GT my measurement devices show slight fluctuation (+/- ~<20 rpm) but my ear has a hard time convincing myself that I hear the fluctuation.
Remember that the spec is 775 +/- 25 rpm.
I may be searching for perfection, when perfection was not present in 1990? just trying to make this
the best I can.
the best I can.
My perception is not as good as what's displayed on my Hammer, SharkTuner, Timing Light, and Durametric.
My perception seems to be able to consistently detect rpm fluctuation in excess of 30-ish rpm only.
Basic Site Sponsor
Basic Site Sponsor
I don't put anything except genuine Bosch-boxed parts under the intake since I have to warranty my work. Cost to diagnose and R&R a bad POS part is too high.
I might try the Lowe part on my SC'd '91 since it takes about 2 minutes to R&R the ISV unlike a stock 87+ where it's hours and hours of work.
I have never seen a dead S4/GT ISV. I have seen them dirty and sticky. A dirty/sticky ISV will cause actuation delay that could cause idle control loop to perform poorly or go unstable (engine dies, idle sticks high.)
They are easy to test and not too hard to clean. Plenty of threads on cleaning. Testing instructions in my inspection guide. Bench testing is obvious. Don't use a cleaner that leaves a residue (like WD-40) or will promote rust (like water.) I use 50/50 ATF/Acetone.
So far everything is consistent with a sticky idle switch and/or dirty ISV. If you want to try the Lowe ISV I can't stop you. But, you should still clean and test your old one and make sure both it the Lowe behave the same (unless your old one can't be made to operate as well as the new one.)
The Bosch part has always been available. For the last several years it's been ~$300. Is your supplier's replacement less than $300? It this 'new' part different from the original?
This issue has me intrigued in a number of ways. I have been chasing a similar concern for time to no avail. I have a slight stumble in the idle. A few months ago I decided to change out my knock sensors that were still working but had connectors that were dropping to pieces so it was an opportune time to tr the Lowe ISV. I found this unit to be visually excellent and when installed it performed exactly like the stock item have used in my motor for the last 19 years of ownership. Thus nothing much lost $$$'s wise and something gained knowledge wise. I consider the used ISV a "working spare" in case the Lowe unit packs up prematurely. This left me wondering if the Lowe unit is made in the same factory as the Bosch unit- just a different name on the box it comes in [and a different price].
I consider my idle not bad but somewhat less than perfect. The slightly uneven idle I detect could be a slight misfire for whatever reason and I intend to do further investigation shortly. In the days when we had a number of 928's over here various owners commented how the idle was a bit on the erratic side- in particular a friend of mine who had a GTS from new. He complained about the idle as part of the initial warranty and the local agents took a number of steps to resolve his concerns but never managed to change his perception.
We know that the GT idles notably higher than the S4/GTS and one wonders why this is needed. Needless to say the GT cam is going to be a bit lumpier because of the higher lift but it is nothing outrageous lift wise. Whilst using ST2 I noted that the idle on my S4 motor was jumping around a bit cell wise- whether this was the system reacting to the slight rpm change or whether it is something going on with the MAF I am not sure but my suspicion is that there may be some impact from reversion pulses given the load values were bobbing around a bit as was the rpm value and the cursor was crossing between two adjacent cells.
I suspect this issue is a limitation of the system and the sensitivity of the owner is the main variable- I tend to be very sensitive to minor fluctuations.
The GT hunting idle problem I diagnosed was a fairly-new perfect-looking CPS that was providing a poor signal to the EZK. This poor signal caused the EZK to 'believe' that the engine speed was hunting through the idle timing map. The EZK was thus, changing spark advance based upon incorrect speed values, thus *causing* the idle to hunt between 600 and 900 rpms. Isolating this fault took a Hammer, messing with idle timing with the SharkTuner on a second set of ECUs, and a timing light with an RPM display. After I installed a new CPS the hunting disappeared and the idle was consistently 775 +/- ~12 rpm.
