Piston Squirters
#92
That's what you get for living in a questionable neighborhood
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Originally Posted by Louie928
Stock except for the oil filler cap vent. That is fed through the smog pump air filter at the center of the fan shroud. The smog pump disappeared. I think someone stole it.
#93
Originally Posted by pmotts
That's what you get for living in a questionable neighborhood ![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
#94
Chronic Tool Dropper
Cool use for the air pump filter housing. This is also the perfect opportunity to recommend a K&N filter for the 928.
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
#95
Originally Posted by dr bob
Cool use for the air pump filter housing. This is also the perfect opportunity to recommend a K&N filter for the 928. ![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
![nono](https://rennlist.com/forums/graemlins/nono.gif)
#97
I may just have the ultra rare smog pump delete option. Code 666.
#99
Originally Posted by Greg Gray
Hi Louie can you tell us what your engine no is to add to the databank? Or is it before the last no.s posted?
Thanks Greg
Thanks Greg
The engine no. on the '87 is M28/41 81H 00236. The engine also has the cast oil filler neck, not the normal S4 plastic one. The VIN ends in 0469 and has the folding rear wing.
The engine block no. on the stroker in my '90 GT is from an '87 and has number M28/41 81H 00460. Possibly a squirter too, but didn't visually confirm it. Marc Thomas built the engine internals. I used that block because the cyl walls were thicker than those on the GT block.
#100
Originally Posted by sweanders
I always thought that option code 666 was thinner laquer protection, I have that option code on the Cup car.. ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
How much weight does that save?
Hmmm. Wonder if I can get license no. 666 for my white beast.
#103
Many many thanks for those who replied, I searching for another squirter block after my first one was destroyed. You guys are great. Kepp them coming please.
Cheers Greg
Cheers Greg
#104
I know this is going to sound stupid and maybe I’m too lazy to research the subject, but would somebody tell me a quick way to locate the numbers on the block?
#105
