928 Forum 1978-1995
Sponsored by: 928 Specialists
Piston Squirters
Old 07-27-2006, 11:46 AM
  #76
folding wing 5 speed
folding wing 5 speed's Avatar
mine came with a folding wing and squirters were in the block. I have bad photos lying around somewhere. Vin is 1134, a little younger than heinrichs or his ex's. I was trying to figure it out once and thought 1400 was as good a guess as any based on Heinrichs cars. FWIW
  #77
Bill Coleman
Bill Coleman's Avatar
Originally Posted by UKKid35
Anyone got an earlier S4?
Paul,
Mine may be older but I don't know the serial number off the top of my head. What's your VIN? I have #0142, 8/86 build date. I'll try and check the block when I get home.
Old 07-27-2006, 11:47 AM
  #78
heinrich
928 Collector
heinrich's Avatar
Agreed with Folding Wing above.
Old 07-27-2006, 11:48 AM
  #79
heinrich
928 Collector
heinrich's Avatar
Default What about '86.5 blocks ....
Which brings us to a veeeeery interesting question........
Old 07-27-2006, 11:49 AM
  #80
heinrich
928 Collector
heinrich's Avatar
Sterling I believe they do, and I believe they are susceptible even to massive oil ingestion as a result, but ALL through the crank case ventilation system.
Old 07-27-2006, 11:52 AM
  #81
Ispeed
Ispeed's Avatar
mine is 1491 and has the folding wing. I will have to check build date and look for serial #s.
Old 07-27-2006, 11:55 AM
  #82
heinrich
928 Collector
heinrich's Avatar
Well yes there is that ..... there is some overlap of wing/no-wing at 1400 or so. My 5-speed 1401 had no wing and 1385 did. Maybe wingness is not a good gauge then for squirterage. We do know that there were squirters up to 1401. Or we think we know that
Old 07-27-2006, 11:57 AM
  #83
heinrich
928 Collector
heinrich's Avatar
Yes, true Sterling, and they also happen to be the natively high-horsepower beasts.
  #84
heinrich
928 Collector
heinrich's Avatar
SHANE:
I'll bet Helmut has squirters.
  #85
Ispeed
Ispeed's Avatar
Build date 02/'87 and block # M28/41 81H00836
Old 07-27-2006, 12:07 PM
  #86
Loaded
Loaded's Avatar
my srt8 6.1 hemi has them I havent seen any oil usage with it.
Old 07-27-2006, 12:25 PM
  #87
heinrich
928 Collector
heinrich's Avatar
Fausto, there is a massive difference in the two engines and how they interact with oil.
Old 07-27-2006, 02:48 PM
  #88
Louie928
Louie928's Avatar
Originally Posted by Sterling
Here is a question.... Does anyone know if the engines with squirters burn more oil due to more oil being suspended in the air inside the crankcase?
Sterling,
My '87 has squirters and oil comsumption is very low. I've got about 3500 miles on this oil change (Redline 20W 50), and it's less than a quart low. Most of that leaked out.
Old 07-27-2006, 02:56 PM
  #89
heinrich
928 Collector
heinrich's Avatar
Louie do you have the stock breather system?
Old 07-27-2006, 06:55 PM
  #90
Louie928
Louie928's Avatar
Stock except for the oil filler cap vent. That is fed through the smog pump air filter at the center of the fan shroud. The smog pump disappeared. I think someone stole it.
Quick Reply: Piston Squirters
