928 Forum 1978-1995
Sponsored by: 928 Specialists
87+ manual transmission destruction, rebuilding, discussion etc....
Old 09-14-2018, 04:19 PM
  #76
ptuomov
ptuomov's Avatar
Broadcasting this periodically: If someone has used 87-88 LSD unit in good condition for sale (part number 92833205220), I'm interested in buying it.
Old 09-18-2018, 12:22 PM
  #77
ptuomov
ptuomov's Avatar
PING! f someone has used 87-88 LSD unit in good condition for sale (part number 92833205220), I'm interested in buying it.
Old 09-18-2018, 01:52 PM
  #78
Mark Anderson
The Parts Whisperer
Mark Anderson's Avatar
We should have one later this week
Old 09-18-2018, 03:29 PM
  #79
ptuomov
ptuomov's Avatar
Let me know what you get. Right now, the most pressing need is for an '87-89 LSD unit.
Old 09-22-2018, 05:30 PM
  #80
ptuomov
ptuomov's Avatar
At what measured surface hardness are steel gears usually the toughest in terms of their ability to hold load? 400 Brinell?
Old 09-22-2018, 06:14 PM
  #81
slate blue
slate blue's Avatar
I'm no expert, but isn't Brinell used for aluminum and Vickers used for steel, I think one is a ball test the other a point test. I could be wrong...
Old 09-22-2018, 10:45 PM
  #82
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
Received 2,458 Likes on 1,460 Posts
You know the transmission came with a limited slip, right?
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
Old 09-23-2018, 12:32 AM
  #83
ptuomov
ptuomov's Avatar
Rob’s, yes. But I’ve got another one with an open differential.
Old 09-23-2018, 01:04 PM
  #84
Wisconsin Joe
Wisconsin Joe's Avatar
I think Brinell is just the 'ball test'. It can be used on a wide variety of materials. I've mainly seen it used on lead (cast bullets).
Old 09-27-2018, 11:37 AM
  #85
ptuomov
ptuomov's Avatar
Default Can anyone identify LSD’s?
Any help with identifying these LSD units based on numbers? I’m looking for ‘87-89 units.
Old 09-29-2018, 06:29 PM
  #86
ptuomov
ptuomov's Avatar
I read about that and it turns out these gears should be tested using the Vickers or Knoop tests.
"For instance when hardness is checked on a mounted tooth sample, it is typically checked by taking a microhardness traverse. The microhardness is taken either by Knoop, a method using a 500- or 1000-gram load, or sometimes Vickers, using a kg load. Yet nearly all drawings specify surface and core hardness in values of Rockwell "C", a method which uses a 150 kg load. For this reason, a conversion must be made from either the Knoop number or the Vickers number to determine whether the part met the specified Rockwell number. Conversion is not simply a mathematical relationship. Since the structure and cold working properties vary for different materials and hardnesses, The 150kg load used for a Rockwell "C" check is inappropriate to check the hardness close to the surface or elsewhere in the case. This is because the size of the indention made by the 150 kg load homogenize the conditions over a large area. This can mask local deficiencies."
Mpfaff (06-27-2019)
Old 09-30-2018, 01:37 AM
  #87
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,557 Likes on 1,236 Posts
Greg has a Rockwell hardness tester on a stable table at the shop, but I've never seen him use it on a gear. Not sure which sets of indenters he has nor which sets of hardness scales it can be set up to measure.
Old 09-30-2018, 09:33 AM
  #88
ptuomov
ptuomov's Avatar
John Kuhn had some gears measured at a lab, which used Knoop method. The Knoop method is local enough to be useful for gears, while Rockwell C test is not as useful. What's confusing is that the reference values are often quoted in HRC even though they aren't measured with that method.
Old 10-09-2018, 10:05 PM
  #89
ptuomov
ptuomov's Avatar
Default Nothing yet
[premature, deleted]
Old 10-10-2018, 04:46 PM
  #90
Bigfoot928
Bigfoot928's Avatar
tease
Quick Reply: 87+ manual transmission destruction, rebuilding, discussion etc....
