rack reseal
rack reseal
I am in the process of resealing my steering rack ...have not yet gotten the parts but is there an exploded view of the rack seals , etc and a description of the part...I found an exploded view with the parts all numbered, but where can I find the description based on the numbers???...
THANKS
Tom Taylor
'87 5 speed s4
THANKS
Tom Taylor
'87 5 speed s4
Hey Tom, here's my best efforts, out in front of the world, less then optimal rebuild thread.
If there's a description to that famous diagram I never found it -- to answer your question.
https://rennlist.com/forums/928-foru...86-5-gulp.html
May the force be with you sir.
Regards.
Dave
Regards.
Dave
The 928's rack is very similar to the 944 rack so if you have questions about it you can probably get some good advice from a site called "Clark's Garage" (http://www.clarks-garage.com/), a wealth of information on the 944. There's a seciton in the workshop manual that discusses rebuilding a power steering rack that's largely applicable.
https://rennlist.com/forums/928-foru...tart-with.html
... despite the intimidating number of parts in the bag it is easy to separate them into piles and where everything goes becomes pretty obvious when you compare the old and new parts.
