ok,hatch opens but won't close with with pull-button.
Ok... I did some tests....fuse is ok , I used some contact cleaner just to be sure ... System works in 7 of 10 attempts .when system is not parking, I pulled again the **** and it looks like motor complete its "travel ". I checked pull **** and works perfectly.i suspect the motor inner contacts...
Thanks boys... 7 out of 10 is better than zero , worse than 10/10 of past week....
VW release :good but hate non stock parts. And the fact that is faster than stock .. Well, not all that hurry in my life. I will investigate and see if connections are loose, then I will try to disassemble the motor and fix it
problem solved :changed the hatch plastic insert before pulling motor and check inside. i notice the hook was 5 mm "off" and scratched the right part of the new plastic insert. placed correctly , the hatch closes perfectly.
