Using 944 studs on a 928 S2
Last week I asked why the cylinder studs for a 944 where half the price of the 928 S2 when they were exactly the same length. I ordered one so I could see for myself and below is a picture of a old 928 stud next to the one I received (the longer 193mm ones) . As you might be able to see the 944 thread has fewer threads than the 928 one (approximately 20 into the block and 10 at the nut end) my question is- is that enough to hold the head when I torque it down without stripping the block, or should I bite the bullet and get proper 928 ones for more than twice the price?
Not that I am aware of, but I would think there is a reason that they are engineered that way, else why make a new part that adds to the bottom line of production.
Sometimes $ short cuts are more costly in the end
Dave
Dave
Hmm... It could be that Porsche established the part for the 928 and was shaving pennies on the 944. If the head is the same thickness and the compression is similar, then I don't see why the 944 studs wouldn't work just fine.
Administrator - "Tyson"
Are those 944 8V or 16V studs? Are those the same in the 944 world?
That seems backwards, but my 944S is too buried to measure right now.
83 - 88:
944 101 197 00
89 - 91:
944 101 197 01 - M44.11/12
944 101 197 00 - M44.52
944 101 197 03 - M44.41
Lindsey Racing carries all four, I'd sent them an e-mail seeing if they can report back the length differences.
944 101 197 00
89 - 91:
Shouldn't be the case. I'm not an engineer, but if my understanding is correct, what determines the ability of the bolt to hold is the amount of thread surfaces in contact. Imagine the thread stretched out into a continuous thin 'blade' as long as the turns around the bolt. If you attached a wire to the center of the blade and pulled down against the length of the blade, you'll get more strength with a longer blade than a shorter blade.
Not to keep banging on about this but a picture of the studs ARP make for the 928 shows the same number of threads as the 944 studs going into the block (the nut end has a finer pitch though)
Rainman
there are several different 944 stud lengths.
2.5L 8v (which works on some early 2.5 16v heads)
2.5 16v (heads got revised mid-year to have thicker head stud holes so studs got longer)
2.7 8v (the block threads for the stud got raised considerably with the block redesign for 104mm bore)
3.0 16v (raised threads, and the bigger 16v head)
bear in mind that the 928 has a 2mm higher deck height than a 944 so there is potential for a longer stud required for that reason alone.
