'90 A/C Belt Excesive Wear
I was inspecting underneath the '90 GT this morning and notice a lot of wear on the A/C belt after trip to Sharks to Ontario. It appears that it is not aligned with the crank pulley and tracking at an angle. What would cause this? What is the remedy?
Thanks everyone......
A local chap had a similar issue, thread below.
https://rennlist.com/forums/928-foru...-question.html
OK. The other alternator & P/S belts are tensioned and fine. The part of the pulley that the air pump belt rides was hacked up by the PO that didn't use a flywheel lock (I assume) and I have one on order. That belt was chewed up also. The thrust washer is figure #12 in the PET or #6 (x2)?
I'm just about to put the AC compressor on the 89 motor. I could take some detailed measurements if that would help ruling out a miss alignment of the compressor.
That would help Adam. Looking again the P/S is a little tweaked also. I'm going to look for one of the #6 washers missing. Will report back when I find out.
Update: The 2 washers (#6) are in place with the lips of the outer edges away from the crank gear. A/C belt is not straight with my eyes looking down the length of the belt. The A/C pulley on the crankshaft needs to move closer to the block or the A/C compressor needs to move closer to the radiator. Can't see how I would do either. My next step I suppose is to check the A/C mount? The air pump is still a problem also. Something on the bracketing on that side of the engine must be miss aligned/broken/ bent??
Did you figure this out..? Inquiring minds wanna know!!
Received 1,638 Likes
OP? Is your airpump still installed? Or has it been removed?
Former Sponsor
Something else going on here....a picture or two is probably in order.
Update: New belts installed and probably 60 miles of driving and no fragments of belt material. Re-tensioned all belts. All seems to be good now. Will report any change or wear in the future.
