Launching experiences... (burnout or lack thereof)
So... I'm trying to figure out if my experience is normal, or if I've got something new to look into on the 951. The bottom line is.... failure to launch. Now, to be honest I do have a healthy respect (or fear?) for the R&P on these, so I've never done a launch from like redline or anything. But I have tried to launch from around 4k.... and pretty much nothing happens. No wheel spin, and not even a whole lot of takeoff. Basically, it just instantly drops my RPM's to about 1k, and I build up again from there. Just about the same experience as if I'd been moving a little bit and floored it from 1k.....
Is that normal for decent tires and LSD? Do you have to launch from up around 5-6k to get a "real" launch? I don't think I'm slipping my clutch, cause my RPM's drop like a rock. And I've NEVER been able to break the tires loose (shifts to 2nd at 5.5k aside). But I see post about burnouts, I don't think mine can even DO that. Is that normal, or do I have something up?
I kinda get the feeling my tires are just sticky enough that with the LSD I'm getting just too much traction. So instead of really launching I'm just bogging. Clutch is new, and is a bit grabby in 1st and reverse. I really don't have enough travel in "engage" part the pedal to have a lot of control on slip. It's mostly either disengaged, or engaged, without much between. I use the throttle more than the clutch when getting going. Since my other is an automatic, I have nothing to compare to. Looking for input...
I only do it rarely, but my S doesn't have much trouble getting wheelspin on a hard launch. I don't have LSD and my tires aren't anything that special (high-performance all-seasons, so better than a standard passenger car but definitely not a sticky race tire).
Are you just dumping the clutch? That's going to be pretty rough on the drivetrain and, as you discovered, it drops your RPM and takes you out of boost. On manual cars, and especially turbo'd cars that tend to be weak off-boost, you want to feather the clutch a bit to help keep the RPMs up. If you just dump the clutch, you get bogging and a lackluster launch.
This is the reason I'm thinking of selling mine and I just got it. Without modding these cars they just aren't fast by any stretch of the imagination. From a dig, roll, 4K, 5k any k for that matter. Lol. I am hesitant of modding because the car just runs solid and is bone stock. I mean the car is a lot of fun and is somewhat quick but burnout? I'm not ready to dump 3k on a clutch. I was just expecting more out of it. They are nice cars though
I've never tried a hard launch - these cars are just not made for that. It's certainly not a long term repeatable event anyway.
Once rolling though, I hit full boost every chance I get.
when the tires hook up, it sends a shock through the driveline...the rubber center is the weak point then ring and pinion teeth, ect.
burn outs should be limited to rental cars and your mothers buick.
We used to run an autocross course that needed a good solid launch. I always found the best way was a slip-dump. With a good clutch, it feels really fast. Usually starting about 4000RPM slip the clutch for the half a second then dump the rest of it. I think that lets the driveline accept the force without impact loading it.
This is the reason I'm thinking of selling mine and I just got it. Without modding these cars they just aren't fast by any stretch of the imagination. From a dig, roll, 4K, 5k any k for that matter. Lol. I am hesitant of modding because the car just runs solid and is bone stock. I mean the car is a lot of fun and is somewhat quick but burnout? I'm not ready to dump 3k on a clutch. I was just expecting more out of it. They are nice cars though ![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
If you were thinking of selling it because of its inability to hard launch or burn-out, do it now before it turns into a dogs breakfast and isn't worth what you've just recently paid for it.
While the R&P on the turbo cars is stronger than the N/A cars, hard launches are not its friend. These cars were just not designed for that.
Turbo has a 3.36 ring and pinion and low compression ratio. Unlike a supercharger where engine speed controls boost a Turbo depends on engine load. It doesn't take much throttle to rev a Turbo engine to redline so no boost, hence poor launching.
I'm not wanting to burnout per say, I was just wondering if my experience was normal or if I had something not right with the car. I had just read some post about people "burning rubber" and getting burnouts so I was thinking maybe I had some issue somewhere.
But it sounds like my experience is normal, especially with my slightly sticky tires and LSD. I haven't tried a launch at more than 4k, and to be honest I'm just trying to get an idea of the best way to launch these cars. Mainly just so I know HOW to, not that I want to do it often. I baby this thing to be honest.
I don't WANT to burnout!! That's just wasting power anyway, what I was trying to get at is if it SHOULD burnout when launched, and mine just wasn't.
I've got my answer, and I'm happy with that!
I hit wheel hop /spin pretty easy, but I've got a 968 engine.
Go find some canyons and keep the car spooled up, you'll like your turbo more. These are not straight line cars really. They rip in the twisties though.
+1 True that! My last Trans Am I was going to build a 400 HP launch monster. Ended up building an autox King. Seems as I got older my interest shifted to a different kind of driving. I got a 944 for the handling (and the awesome styling). Thanks for the feedback! Glad my experience is normal.
