944 S2 intake manifold on 944S
I recently fitted the S2 manifold to the S, and i was wondering if many others had done the conversion.
It was a simple mod, with no issues, and the results were impressive.
Using GPS lap timing, before mod the car pulled 0- 100mph in 21s, now she takes just over 18s. tests conducted one week apart, on same stretch of road, similar weather conditions ie not windy, same time of day ie night time..exact same stretch of road used to minimize errors.
I did a 1/4 mile and I had retarded the camshaft about 0.5 deg (i was testing different cam shaft positions) and she ran a 15.50 at 92 mph, i later put the cam timing back to stock and the performance improved (verified by pants dyno, compression went from 180 to 205 psi in all cylinders).
you need the following parts from an S2
intake, throttle body, oil filler neck and dip stick, rubber boot which goes between TB & MAF, aluminium cast adapter which goes between MAF and air filter.
you will need a 90 deg silicon tube to attach to said aluminium adapter, and a K&N air filter.
vacuum line connection is easy and as per S2 manual.
the only pipe you dont need to connect or use is for the heater tubes which heat up the TB
you will use the original throttle cable if you like, like i did i will attach a photo
i am trying to attach a photo but with no luck. anyway i used the original throttle cable, if anyone needs to know how i can send them a photo by email when they get to the stage of performing the mod.
I am surprised not many people have done it, the performance improvement was night and day, infact the original car was fairly weak and sluggish compared to how it is now.
Thanks!
LOL, seriously guys...., a 3 second 1-100 improvement from swapping an intake..?
It'd take roughly +30 bhp to take a 3000 lb car 0-100 in 3 seconds faster.
That;s more horsepower than the difference between the 2.5 liter and the 3.0 16V.
Who knew Porsche didn't have to increase the stroke and bore....., just install the intake.
T
T
Just a car guy
T
T
Uhm, no.
I'm doing a 944S engine and I don't even want to talk about what $$ I'll have into making an additional 30-40hp.
T
Hello T. What kind of build are you planning?
I’m planning an NA build for my 944S next winter. Im thinking seriously about stroking my stock crank, but may go with a S2 instead.
-Bill
-Bill
1st oversize bore, Alusil cylinder, Wossner pistons, Performance Developments Crankshaft, Molnar rods, 4 piece billet custom grind cams with adjustable central timing gears, PCA legal (no porting) MM cylinder head, tuned header.
S2 + power with the 2.5 16V S platform.
T
Past the planning stage....,
T
T
-Bill
Haven't decided yet but I already have a never been used E48 and brand new terminated 944 specific harness.
Had it posted for sale at Pelican months back because it's plug and play for a 944T (what I had it originally configured and purchased it for) but it seems nobody sees/knows the potential of this ECU.
So I might as well beat them with it....
T
Rainman
Tuned stock Motronic or DTA/FAST E48 with cap and rotor intact per SP3 rules,
T
T
