Vibration in front end during turns
Lately I've noticed when I turn at speed - like on sharply curving highway ramps for instance - I can feel the front wheels bumping around like crazy. It feels like I'm driving on a very rough surface even when it's smooth. Through the steering wheel it feels like the wheels are slipping around a bit. But it only seems to happen when one side of the car loads up in a turn. In a straight line, or lower speed turns, it's fine.
The front sway bar is not on the car, but I've had that removed for a long time, and I haven't noticed this before. Still maybe that could be it?
Everything seems nice and tight at the front wheels. Wheel bearings have normal play. Everything is fairly new - tie rods, steering rack mounts, wheel bearings, ball joints etc. Tire pressures are normal and the tires are in good shape. The alignment should be pretty much spot on too.
Any ideas what could be causing this?
Nope it's 100% stock.
Sounds like uneven tire wear on the inside edge and when the camber changes, like at speed on sharply curved roads, you are riding more on the worn edge. Sometimes it's difficult to see the wear unless you take the tire off and check/measure the thread. Look for feathering of the thread pattern and less thread depth inside to outside edge. Might be worth swapping the rear wheels to the front and see if that cures it.
Sounds to me like something is loose. Jack the car up and start wiggling things. Likely culprits are:
-Wheel bearings
-Ball joints
-Tie rod ends
-Strut top mounts
-Wheel bearings
-Ball joints
-Tie rod ends
-Strut top mounts
Well I had a good look today there's definitely nothing loose, at least that I can tell from trying to move things with the wheels in the air. The wheel bearings have a tiny bit of play, but they've had that since I replaced them. They are a few years old now, but I don't think they're the problem.
The feeling I get in the corners is not so much looseness but more that the tires are getting pushed around by the road...a bit like a go-kart. That's the best way I can describe it.
Alignment should be factory spec, although it's a while since it was done. Tire wear is perfectly even so far, but I suppose if something happened to the alignment recently it might not show up in the tires yet.
https://www.youtube.com/watch?v=FwLX...ature=youtu.be
(The noise is just the steering wheel hitting the stops)
It looks like the control arm bushing is moving as much as the tie rod! That can't be normal can it?
Both sides are exactly the same. I replaced them 3 years ago along with the ball joints. I pulled one ball joint out of the knuckle and its still as tight as it was when I installed it. I wonder how the rubber bushings could get this loose so quickly.
