924/944/951/968 on ≥18'' wheels, Post yours!
Lets see what you have.
Roock Competition, 18", Fronts - 8.5" (255/45/18), Rears - 10.0" (265/35/18).
Same wheels with centers plasti-dipped.
rodeoj (04-27-2023)
18X10 wheels front (ET58mm) and rear (ET52mm). 255-35-18 front tires (25.0" OD), 285-30-18 rear tires (24.7" OD). Street tires on these wheels. If I go to the track with this car I would generally swap on some race rubber which is on 16's or 17's... or even 18's... and sometimes I mix and match wheel diameters gasp!
In the rear, it's at the lowest of the factory adjustment with the trailing arms. Because it's a Turbo S, the front has always been adjustable. It's on Bilstein Escort Cup shocks in that picture. I adjusted it to match the rear ride height and then corner balanced.
Here's mine. Work Meisters, 18x9.5 all round with 255 or 265 wide tires.
They weigh 10.5kg each, so about 20kg with a tire.
