How to remove bump stop on Koni rears?
I want to adjust my rear koni shock harder for 18" wheels. How do you get the bump stops out. It seems like they would get torn up trying to pull them out. They don't seem to move easily.
I sprayed a lot of lithium grease in there and was able to break them loose.
However, upon further inspection, I found the right side shock is rebound much slower then the left side.
Yes, OE Koni's. Are they shot?
Your Porsche Parts Superstore
![](http://www.paragon-products.com/v/vspfiles/assets/images/pagidrs2.jpg)
![](http://www.paragon-products.com/v/vspfiles/assets/images/Paragon web logo.gif)
![](http://www.paragon-products.com/v/vspfiles/assets/images/konilogobkbgsm.jpg)
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Jason Burkett
This work bench dyno test doesn't really tell you much as you haven't developed enough force to even open the valving. More than likely one shock has a bit more stiction between the piston and the top seal which doesn't mean squat to it's actual operation. With that said, if you need new Koni's we'd be glad to help. ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
However, the ride is stiffer. I wonder what impact too much dampening and not enough spring rate has. Does higher spring rate and less dampening achieve a better ride on the street? I do not track the car.
